Datsun 1200 GX used a matched pair of 38mm sidedrafts, referred to as front and rear carburetors. These are similar to S.U. brand carburetors. For more general information see Hitachi Twin Carb.
Variations
Three variations were used in the 1970-1972 B110 JDM GX model run. All are dome-tops:
- Original
- 16010-H2332 CARBURETOR ASS'Y-twin, front
- 16010-H2333 CARBURETOR ASS'Y-twin, rear
- November 1971
- 16010-H2334 CARBURETOR ASS'Y-twin, front (from '71-11)
- 16010-H2335 CARBURETOR ASS'Y-twin, rear (from '71-11)
- January 1973
- 16010-H2336 CARBURETOR ASS'Y-twin, front (from '73-1)
- 16010-H2337 CARBURETOR ASS'Y-twin, rear (from '73-1)
Part Names
Parts Breakdown
- 1 16122-H2310 SHAFT ASS'Y-throttle
- 2 16324-H2310 FILTER ASS'Y-piston
- 3 16144-H2310 NUT ASS'Y-idle adjusting
- 16144-H2311 NUT ASS'Y-idle adjusting (from '71-11)
- 4 16145-H2310 SPRING-idle adjusting screw 2
- 5 16355-H2310 NOZZLE ASS'Y
- 16355-H2310 NOZZLE ASS'Y (from '71-11)
- (6) 16127-H2310 PLATE ASS'Y-throttle adjusting, front
- 6 16127-H2311 PLATE ASS'Y-throttle adjusting, rear
- (7) 16277-H2312 LEVER ASS'Y-first idle, front
- 7 16277-H2313 LEVER ASS'Y-first idle, rear
- 16277-H2315 LEVER ASS'Y-first idle, rear (from '71-11)
- 16134-H2310 LEVER ASS'Y-throttle, front
- 8 16134-H2313 LEVER ASS'Y-throttle, rear
- 9 16083-58000 SLEEVE 2
- 10 16214-25610 NUT (8 radius) 2
- 11 16116-H2310 SLEEVE 2
- 12 16190-10401 SPRING-starter, return (B)
- 12 16190-74310 SPRING-starter, return (A)
- 13 16147-14611 PLATE-cam (B)
- 13 16147-74311 PLATE-cam (A)
- 14 16116-14610 SLEEVE (B)
- 15 16157-14610 SPRING-connecting (B)
- 15 16157-74310 SPRING-connecting (A)
- 16 16238-H2310 LEVER ASS'Y-choke, front
- 16 16238-H2311 LEVER ASS'Y-choke, rear
- 17 16147-H2310 PLATE-connection, front
- 17 16147-H2311 PLATE-connection, rear
- 18 16227-H2300 ADAPTER-front
- 18 16227-H2311 ADAPTER-rear
- 19 16322-E3210 BOLT (8Ø) (2)
- 20 16356-25610 PIPE-rubber, fuel (2)
- 21 16358-E4310 CLIP-fuel pipe (4)
- 22 16061-10400 FLOAT
- 23 16101-H1000 VALVE ASS'Y-needle
- 16101-18010 VALVE ASS'Y-needle (from '71-11)
- 24 16062-10400 LEVER-float (up to '71-10) (2)
- from '71-11
- 16062-H2310 LEVER-float, front (from '71-11) (1)
- 16062-H2710 LEVER-float, rear (from '71-11) (1)
- 25 16066-25610 SHAFT-float
- 26 16331-10400 SCREW-nipple set
- 27 16098-25710 FILTER
- 28 16554-H2310 JET-needle
- 28 16554-H2316 JET-needle (from '71-11)
- 29 16031-A8710 PLUG-drain
- 30 16148-H2310 CLAMP-choke, front
- 30 16149-H2310 CLAMP-choke, rear
- 16149-H2311 CLAMP-choke, rear (from '71-11)
- 31 16346-10615 SPRING-suction
- 32 16341-25610 NUT ASS'Y-oil cap
- 33 16194-H2310 SPRING-throttle
- 16194-H2311 SPRING-throttle (from '71-11)
- 16194-H2312 SPRING-throttle (from '73-1)
Piston with Needle Jet and needle set-screw
GASKET SET
- 16455-H2310 GASKET SET
- A 16335-14610 PACKING (10Ø) (4) [for inlet banjo]
- B GASKET-float chamber (2)
- C WASHER (8Ø) (2) [for fuel drain plug]
- D PACKING (18Ø) (2)
- E WASHER (10Ø) (2) [for fuel needle & seat ASSY]
SCREW & WASHER "B" SET
- 16475-H2310 SCREW & WASHER "B" SET
- F PACKING (12.5Ø) (2) [for piston rod]
- G WASHER (7Ø) (4) [for pump lever end]
- H WASHER (5Ø) (2) [for lever linkage]
- WASHER (4Ø) (2)
- I PIN-cotter (1Ø) (2) [for pump lever]
- J WASHER-thrust (2) [for throttle shaft]
- K BOLT (5Ø) (2) [for lever linkage]
- BOLT (5Ø) (2)
- L WASHER-lock (7Ø) (2) [for lever linkage]
- M SCREW-set, needle jet (2) [these screw into the piston]
SCREW & WASHER "A" SET
- 16465-H2310 SCREW & WASHER "A" SET
- N SCREW (5Ø x 16) (16) [for dome, etc]
- O SCREW (5Ø x 12) (2) [for choke cable bracket]
- SCREW (4Ø x 10) (2)
- SCREW (4Ø x 8) (4)
- P WASHER-lock (8Ø) (4) [for though-bolt which fastens float bowl to throttle body, and for throttle lever next to tubular nut]
- Q WASHER-lock (5Ø) (18) [for choke cable bracket, dome screws, etc]
- R WASHER-lock (4Ø) (2)
Carburetor Linkage
- 1 08915-43810 WASHER-plain (4) [fixing carburetor to manifold]
- 2 08915-13810 WASHER-lock (4) [fixing carburetor to manifold]
- 3 08911-20810 NUT (4) [fixing carburetor to manifold]
- 4 16361-H2300 SHAFT ASS'Y-throttle
- 5 16376-H2300 BRACKET-accelerator cable
- 6 08915-13510 WASHER-lock,fixing accelerator cable bracket 2
- 7 08460-51000 SCREW-fixing accelerator cable bracket 2
- 8 16031-H2300 TUBE-over flow, front
- 9 16031-H2301 TUBE-over flow, rear
- 16031-15801 TUBE-over flow, (Vinyl 6 x 9 x 160) 2
- 10 14012-H2300 BRACKET-over flow tube
- 10 14012-H2330 BRACKET-over flow tube (from '72-5)
Repair Kit
This repair kit contains hard to find parts. But only the GASKET SET is normally needed. If your carb leaks fuel into the fuel bowl (overflows) you will need new Valve assemblies. For A12GX, it uses the same valve assembly as the DCG306 downdraft carburetor (two of them).
Keyster Kit No. K14-0050HW
Datsun Fairlady (Roadster) 1600 SPL311, 2000 SR311, S30 R, 1600 L20, 2000cc 1965- For carburetor No. 16010-14603, 25601, 16010-E32001
Keyster Kit No. K11-0050HW (DCK-10)
From 1965 Aug Fairlady R16 carb 16010-14603 From 1970 Aug Datsun 1200GX A12 carb 16010-H2300-1 16010-14603RK GASKET KIT K12-0050HW NEEDLE K25-0050HW Appears to contain one Needle Jet for 1200GX and one for Fairlady
Keyster Kit No K15-4676HW
From 1979 Oct Datsun Bluebird 910 SSS L18T Carb 16010-K1433(FR) 16010-K1433RK Gasket Kit K12-0050HW Needle K25-411H
