Bumpers are the same for USA and Japan markets, except for 1973 USA model bumper.
NOTE: 1973 parts fit older brackets, but older bumper doesn't fit newer brackets.
Front Bumper (Coupe & Sedan)
- 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
- 62651-H1000, H1001, H1900 ASSY-BUMPER,FRONT Sedan, Coupe
Rear Bumper, sedan
- 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
- 85011-H1900 BUMPER-REAR CENTER Sedan
- 85012-H1000 BUMPER-REAR RH Coupe, Sedan
- 85013-H1000 BUMPER-REAR LH Coupe, Sedan
62663-18000 BOLT-SPECIAL M6 FIX BUMPER CENTER TO SI 08915-13610 WASHER-LOCK FIX BUMPER CENTER TO SI 08911-10610 NUT-HEX M6X1.0 FIX BUMPER CENTER TO SI 08915-53610 WASHER-PLAIN FIX BUMPER CENTER TO SI 85204-H1000 STAY-BUMPER REAR 85204-H7000 STAY-BUMPER REAR 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER 08114-01610 BOLT 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER 08915-44010 WASHER-PLAIN 08915-13610 WASHER-LOCK M6 FIX STAY TO BUMPER 08915-14010 WASHER-SPRING 08911-10610 NUT-HEX M6 FIX STAY TO BUMPER 85206-H7000 BRACKET-BUMPER REAR SIDE RH 85206-H1000 BRACKET-BUMPER REAR SIDE RH 85207-H1000 BRACKET-BUMPER REAR SIDE LH 85207-H7000 BRACKET-BUMPER REAR SIDE LH 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER 08915-43610 WASHER-PLAIN M6 FIX BRACKET TO BUMPER 08915-13610 WASHER-LOCK FIX BRACKET TO BUMPER 08911-10610 NUT-HEX M6X1.0 FIX BRACKET TO BUMPER 08110-82062 BOLT-HEX WITH WASHER FIX STAY TO BODY 08915-53810 WASHER-PLAIN FIX STAY TO BODY 62685-73000 WASHER-RUBBER FIX STAY TO BODY 62678-21000 SHIM-BRACKET BUMPER SIDE FIX BRACKET TO 08110-61862 BOLT-HEX WITH WASHER FIX BRACKET TO B 08915-53610 WASHER-PLAIN FIX BRACKET TO BODY
Rear Bumper, Coupe
- 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
- 85011-H1905 BUMPER-REAR CENTER Coupe
Overriders
85020-H1900 OVERRIDER-REAR BUMPER RH 85021-H1900 OVERRIDER-REAR BUMPER LH 85020-H7000 OVERRIDER-REAR BUMPER RH 1973 85021-H7000 OVERRIDER-REAR BUMPER LH 1973 62674-H1900 OVERRIDER-FRONT BUMPER RH 62675-H1900 OVERRIDER-FRONT BUMPER LH 62674-H7000 OVERRIDER-FRONT BUMPER RH 1973 62675-H7000 OVERRIDER-FRONT BUMPER LH 1973 85024-H1900 RUBBER-OVERRIDER (4)
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Front Bumper
- 62651-H1000 ASSY-BUMPER,FRONT [sedan/coupe/van]
- 62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
- Two-piece welded vs Three-piece welded
Rear Bumper
- 85011-H1800 BUMPER-REAR CENTER Coupe
- 85011-H1400 BUMPER-REAR CENTER Van
- 85011-H1000 BUMPER-REAR CENTER Sedan
Japan Sunny Truck
Front
- Assembly Early
- 62651-G1001 BUMPER ASS'Y-front STD -7509
- 62651-H1025 BUMPER ASS'Y-front DX -7509
- 62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 [car-type]
- Assembly Late - rubber ends
- 62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 [CHROME + rubber]
- 62650-95W00 ASSY-BUMPER,FRONT Truck from 8910 [BLACK + rubber]
- 62024-G1060 BUMPER-FRONT [rubber end cap] RH from 7804
- 62025-G1060 BUMPER-FRONT [rubber end cap] LH from 7804
- 08360-61026 SCREW 7804-8910
- 08911-10637 NUT 7804-8910
- Side Brackets
- 62672-H1001 BRACKET-FRONT BUMPER SIDE, RH
- 62673-H1001 BRACKET-FRONT BUMPER SIDE, LH
- 62663-G1050 BOLT-bumper "B" STD -7509 [side, exterior]
- superceded 62663-15401 STD
- 62663-27700 BOLT-CARRIAGE [side, exterior] -8503 CHROME METAL (CR-10S) (2)
- 62663-G1900 BOLT [side, exterior] 8504-8910 CHROME METAL (CR-12S) (2)
- 62663-G1205 BOLT [side, exterior] 8910- BLACK ハンツトヤノソウ (2)
- 08915-43610 WASHER (2)
- 08915-13610 WASHER-LOCK (2)
- 08911-10610 NUT (2)
- 62678-21000 SHIM-BRACKET BUMPER (2)
- 08360-61626 BOLT (fixing bumper side to fender)
- replaced 08360-62014 -7509
- 08915-43610 WASHER-plain -7509
- Stays
- 62670-H1002 STAY-FRONT BUMPER, RH
- replaced 62670-H1001 STAY-front bumper (R.H.) (up to '72-6)
- 62671-H1002 STAY-FRONT BUMPER, LH
- replaced 62671-H1001 STAY-front bumper (L.H.) (up to '72-6)
- 62663-G1050 BOLT-bumper "B" STD (4)
- 62663-27700 BOLT-CARRIAGE (4) [external, to bumper] EXC STD
- 08915-43610 WASHER-PLAIN (4)
- 08915-13610 WASHER-LOCK (4)
- 08911-10610 NUT (4)
- 08124-23010 BOLT (4) [to body panel]
- superceded 08114-25510 (from '72-7)
- replaced 08110-81662 (up to '72-6)
- 08915-14210 WASHER-LOCK (4)
- 08915-44210 WASHER-PLAIN(4)
- replaced 08915-53810 (up to '72-6)
- Hook (-7509)
- 62682-H7000 HOOK-tie down (R.H.)
- 62683-H7000 HOOK-tie down (L.H.)
Rear
- 85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7611
- 85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
- 85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7611
- 85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
- 08310-64512 SCREW [external] 7510-
- 08915-43610 WASHER-lock
- 08310-64510 SCREW [external] -7509
- 08915-43610 WASHER-LOCK
- 08110-61810 SCREW [internal]
- 08915-13610 WASHER-LOCK 7510-
- 90802-G1000 BUMPER RUBBER-TAIL GATE -7603
- 90802-G1001 BUMPER RUBBER-TAIL GATE 7604-
- 08310-62012 SCREW (2)
