Keys on some 1200s in some markets are matched: One key opens all doors as well as operates the ignition. In other markets there is a different key for the ignition. Also there are left-hand and right-hand keys that otherwise look identical.
Usage
1972 USA Owners manual (see pages 3-4 for key information):
Your Datsun is equipped with an ignition key warning buzzer system.
Key Types
Datsun 1200 used one of Two key types: VOSS single-sided or VOSS double-sided (reversible) keys.
OVAL KEYS
VOSS KEY00-00034/VH1000 single-sided
VOSS-type keys (KEY00-00034) were made by Kanto Seiki under license of VOSS of Germany. These were used starting around 1969. The former WASO type (KEY00-00028) were made by Kanto Seiki under license of WASO of Sweden. The only real difference is the length. The VOSS keys are shorter, which means WASO key won't fit in the VOSS cylinder. The longer VOSS keys should never be used in a WASO cylinder, as it may lock the steering incorrectly.
Use only VOSS type for Datsun 1200
Nissan Motor Keys
Datsun 1200 used VOSS Double-sided keys with the "Nissan Motor" text and "N" symbol.
VOSS double-sided newer shape used in JDM (Sunny Truck) and SADM (Bakkie)
 KEY00-00055? Left-hand $8.27 USD (not KEY00-00056 Right-hand)
Not to be confused with these:
 Older keys
Non-1200 Keys
Do not confuse Datsun 1200 keys with these single-sided VOSS keys. They also had "Nissan Motor" text and "N" symbol, but were used by earlier models e.g. Datsun Roadster.
From http://www5.plala.or.jp/power_planning/key.html:
-  KEY00-00201 non-centered grooves
- Mirror of 00202
 -  KEY00-00202 non-centered grooves
 -  KEY00-00203 centered groove
 -  KEY00-00204 centered groove
- Mirror of 00204
Steering Lock
For USA 1200s, JDM GL and GX, and newer JDM 1200 pickups, the ignition switch bolts to the back of the key cylinder. The Ignition Switch is not strictly part of the Lock Cylinder, but bolts to it.
Fitment of ignition switch into ASSY-LOCK STEERING
 lock 'barrel' Standard Motor Products 1200 US-168L
Left: 1972-1973, Right: 1971. Note addition of ACC position.
1972 USA Owners manual (see page 11):
- KEY00-00035 KEY-BLANK FOR VOSS TYPE [reversible]
 - KEY00-00034 KEY-BLANK FOR VOSS TYPE STEERING LOCK [single-sided]
-  80010-H1913 SET CYLINDER LOCK & KEY
- 48700-H1900 ASSY-LOCK STEERING
- 48700-H1901 ASSY-LOCK STEERING from 0471
 - Reversible key, left-handed
 - 80010-H1914 SET CYLINDER LOCK & KEY
-  80010-H1901 SET-CYLINDER LOCK & KEY
- 80610-H1001 ASSY-KEY [with leather holder]
 -  80600-H1000 ASSY-CYLINDER DOOR LOCK RH
- 80590-10600 CLIP-CYLINDER LOCK
 -  80601-H1000 ASSY-CYLINDER DOOR LOCK LH
 -  84460-H1000 ASSY-CYLINDER TRUNK LID LOCK
 -  76960-H1001 ASSY-CYLINDER GAS FILLER LID LOCK
- 76962-18200 CLIP-CYLINDER GAS FILLER LID LOCK
-  80010-H1902 SET-CYLINDER LOCK & KEY
 -  80600-H1001 ASSY-CYLINDER DOOR LOCK RH
 -  80601-H1001 ASSY-CYLINDER DOOR LOCK LH
 -  84460-H1001 ASSY-CYLINDER TRUNK LID LOCK
-  80010-H1903 SET-CYLINDER LOCK & KEY
-  80010-H1904 SET-CYLINDER LOCK & KEY
- 80610-H1900 KEY (WITHOUT HOLDER)
USA B210 ignition lock is totally different. Clamps at mid-barell instead of end
- 80610-H6200 ASSY-HOLDER,WITH KEY
 - KEY00-00039 KEY-BLANK ST'G LOCK & DOOR
B310
- 48700-U8725 LOCK ASSY-STEERING
 - K9810-H9101 KEY SET -0880
 - 99810-H9101 KEY SET 0179-
 - 99810-H9100 KEY SET -1278
 - KEY00-00039 KEY-BLANK,TYPE L
JDM STD and DX models used a non-locking steering column. The ignition switch was mounted via bracket on the dash:
-  25150-H1010 SWITCH COMP.-ignition B110 STD, DX
- 25157-H1001 BRACKET-ignition switch
 - B120 -7804
 - B120 7804-8910
- 80010-H5000 CYLINDER LOCK & KEY SET
 - 80690-E6000 HOLDER ASS'Y-key
 - 48700-H5000 LOCK ASS'Y-steering
 - 48700-H5010 LOCK ASS'Y-steering
B120
Key style shown here is '86 up.
Lock Sets
- 80010-G1004 KEY SET-CYLINDER LOCK 7510-7803
 - 80010-G1060 KEY SET-CYLINDER LOCK 7804-8109
 - 80010-G1900 KEY SET-CYLINDER LOCK 8110-
Lock Set includes one of the following:
- 25150-G1001 SWITCH-IGNITION [for non-steering lock type] 7510-7803
 - Or
 - 48700-H2010 LOCK SET-STEERING 7510-7803
 - 48700-G1060 LOCK SET-STEERING 7804-8210
 -  48700-G1925 LOCK SET-STEERING 8211-
- Steering Lock Set includes one of the following ignition switch:
 - 48750-H1900 SWITCH-IGNITION 7510-7803
 - 48750-E4700 SWITCH-IGNITION 7804-
All Lock Sets include:
- 80690-E6000 CASE ASSY-KEY [leather case for key]
 - 80600-H1001 CYLINDER SET-DOOR LOCK, RH
 - 80601-H1001 CYLINDER SET-DOOR LOCK, LH
 - 80590-10600 CLIP-RETAINING CYLINDER LOCK (2)
 - 76960-H7400 CYLINDER SET-GAS FILLER LOCK
 - 80590-21000 CLIP-RETAINING CYLINDER LOCK [small, for filler door lock]
- KEY00-00035 KEY-BLANK 8110-
Small clip is for the fuel filler door lock cylinder
Dimensions
Length
Nissan keys come in various lengths. The original Datsun 1200 keys were the short length.
-  Short: ~31 mm groove length
- 2.0 inch overall
 - Original 1200 reversible key length
 -  Medium: ~38 mm groove length
- 2.4 inch overall
 - Used by Datsuns & Nissans 1974-1981, Subaru, and Mazda Cosmo
 -  Long: ~46 mm groove length
- 2.7 inch overall
Width
Width is 8.9 mm at the point where the grooves start.
Width of the teeth area is 7.1 mm
Center groove width: 2.3 mm
Outside groove width: about 1.0 mm minimum (some keys have it machined all the way out, that is to say a wider groove)
Right-Handed vs Left-Handed
The reversible key came in left-hand and right-hand versions. Datsun 1200 used only the left-hand style.
Aftermarket Keys
Two styles were used (center, right). The newer, longer one (left) will work, but is not the original style.
The little groove diagrams below the photos are for the keylock, so they are the reverse of the actual key.
WARNING: The first key is right-handed, while the second is left-handed. Each key comes either way. Be sure to purchase the correct one for your 1200 locks.
Interesting that some 1200s (newer utes?) came with two different keys originally. The 1971-1973 north american models came with single key for ignition, doors and trunk.
Oval Single-Sided Nissan Ignition Key
This is the earlier style for 1968-1971 Datsun, Mazda before the double-sided keys were used. This was used by 1971 USA 1200.
- Nissan: KEY00-00034 (Key-Blank for Voss Type Steering Lock)
 - Ilco/Ilco-Kaba: DA20
NOT THIS Waso:
- Waso Type FH
 - Taylor: D80K
Short Double-Sided Nissan Key
This was used by 1972-up 1200s for the ignition switch.
- Nissan: KEY00-00035 (Key-Blank for Voss Type)
 - Ilco: 62DV
 - Dominion/DL/Hook: DT17
 - Taylor: X10
 -  JMA DAT-8
- Silca : DAT 7
 - HD Hook : C050
 - HD Hook : C50
 - Orion : DA12
 - Errebi : NS3R
 - CEA : NS7
 - RST : D131
 - CB Hook : 212
 - Standard : 212
 - Curtis : DA-21
Long Nissan/Subaru Key
Used by Datsuns, Nissans 1974-1981, Subaru, and Mazda Cosmo. This "long" key is not original to the 1200, but works perfectly fine.
Reversible (left) 2.4 inches long
- Taylor 62DU
 - Ilco X7
 - Nissan M5001
 - Taylor X7
 -  JMA DAT-1D
- Silca : DAT 6R
 - HD : DT19
 - HD Hook : C052
 - HD Hook : C52
 - Orion : DA11L
 - Errebi : NS2R
 - CEA : NS6S
 - RST : D151
 - RST : D151R
 - CB Hook : 214
 - DL : DT19
 - Curtis : DA-21
NOT this! Reversible (Right, mirror image)
- Nissan M4001
 - Taylor X6
 - Ilco X6
 -  JMA DAT-1I
- Silca : DAT 6
 - HD : DT18
 - HD Hook : C051
 - HD Hook : C51
 - Orion : DA11
 - Errebi : NS2
 - CEA : NS6
 - RST : C151R
 - RST : D151R
 - CB Hook : 213
 - CB Hook : 215
 - DL : DT18
 - Curtis : DA-22
Single-sided
- Taylor D80D/D80E/D80F/D80G
Option
- Key Assy (with holder) 80610-H1001
Key Code
When your key gets worn down too far, making a copy results in a poorly-working new key. Instead, have a new key cut from the original key code.
- In Australia, the key cut number was stamped directly into the original keys
 -  Additionally, the code may be stamped on the right-side door lock cylinder. Remove the door panel to get at the clip which holds the lock in.
- Not necessarily stamped on left-side door lock, nor trunk/boot lock, nor ignition lock
In USA, the key cut number was penciled onto the inside of the glove box door:
-  VF: for VOSS single-side KEY00-00034
- mine is marked "1", possibly to indicate my locks are a single-key system
 - VH: for older (pre-Datsun 1200) WASO KEY00-0028
 - Eng*/DOOR: 4-digit key code
Codes
- In the range of (M)5001-(M)6000 (or N) for reversible KEY00-00035/KEY00-00055
 - range 4001-5000 is for mirror image keys (non-Datsun 1200)
Sunny Keys
Outback Lock
Electric Locks
Central locking kit
