Left: B110, Center: B120, Right: JDM B310
Contents[hide] |
Datsun 1200 (B110) uses Type D41 58 mm wide pad, while HB210 and HB310 use similar-looking but wider Type D117 63.5 mm pads.
B110
D41 type 41060-H1006 PAD ASS'Y-front disc brake B110 GL, GX, and all USAFriction pad is 53.1 mm wide, backing plate is 58mm NOTE: Aftermarket pads tend to be closer to 58mm
Pad specs: * Width: 42.5 mm * Thick: 10.3 mm * Length: 53.1 mm * Backing plate: 58 mm
HB210 Early
D206 type, but can use the HB310 pad D117 typeFor 232 mm rotor (Annette 14/15 A) Original spec is a larger pad than the HB310 spec
Pad specs: * Width: 41.2 mm * Thick: 10 mm * Length: 63.4 mm * Backing plate: 63.5 mm * Material: D864P Nisshinbo 41060-S0100 KIT-PAD DISC BRAKE B210 USA -0475 41060-H7900 KIT-PAD DISC BRAKE B210 USA 0575-0775 41060-S0126 KIT-PAD DISC BRAKE B210 USA -0775 41060-H7926 KIT-PAD DISC BRAKE B210 USA -0775 $52.22 USD
HB210 Late
D117 type For 245 mm rotor (Annette 14/15 AL) 41060-U6728 KIT-PAD DISC BRAKE B210 USA 0875- $45.02 USD 41060-U6725 KIT-PAD DISC BRAKE B210 USA 0875- Pad specs: * Width: 41.2 mm * Thick: 10 mm * Length: 61.4 mm * Backing plate: 63.5 mm * Material: S21B Akebono
NOTE: Material was changed to S21B for improved durability at high temperatures and frictional resistance compared to D864P.
B310 A12
D41 type For AN-18 (220 mm rotor) with 12-inch wheels 41060-H7825 PAD KIT-DISC BRAKE B310 CAN.A12 1278-
Differs from D41: * Beck/Arnley 0820100 Premium Organic $9.18
B310 USA
D117 type 2.5 inch backing plate width 41060-U6727 PAD KIT-DISC BRAKE A10 USA -0678 $86.98 USD 41060-U6728 PAD KIT-DISC BRAKE B310 USA $45.02 USD
B310 JDM
41060-A1126 PAD KIT-DISC BRAKE A15,GX,A14.S,K AKEBONO S17A $94.27 USD 41060-H8925 PAD KIT-DISC BRAKE A15 8108- AKEBONO S17A * D37 type41060-M3226 PAD KIT-DISC BRAKE A13S,GL,A12.S,K TOKICO D64P * D41 type
41060-H7825 PAD KIT-DISC BRAKE VAN AKEBONO S21B * D146 type
A10
Type D146 41060-U7426 PAD KIT-DISC BRAKE A10 USA (Datsun 510) 0778- $86.50 USD * Superceeded by D106M-N2087
Sunny Truck
Unique pad; no FMSI type match Nissan 41060-G1985 PAD KIT-DISC BRAKE B120 8910- Width: 108.4 mm Height: 39.5 mm Thick: 16.0 mm
Aftermarket: Tokico TN289 Akebono AN-311K Kashiyama D1080-02 NiBK PN2306 Nisshinbo PF-2306 Sumitomo SN831
Tokico TN289 for B120 89/10-, box also says Akebono AN311, カシヤマ D1080-02
Akebono AN-31 1K (AN-311K) A311K
Labeled "Sunny Truck" and "89,10-" and "B12T,GB12T" [sic]
Mystery
109.5
Is this Sunny Truck?
- Rotor about 8"(203 mm).
- total width of backing plate: 4-5/16 inch (109.5 mm)
- Same as Subaru Justy for 12" wheel? Type 480
- not 289, 291, 311, 314
108.5
108.5 x 40.3 mm
- 108.5 mm total width x 40.3 mm x 14.7 mm thick
- ~4.272" x 1.587" x 0.579" (inch)
- 4-17/64
- Apec 379
- Interpart GBP666
- CHERRY 1.0 1.3 1.3VAN 1.5 DE 09/82 A 08/86
- CHERRY 1.5TURBO DE 09/82 A 05/84
- CHERRY 1.6 DE 09/85 A 08/86
- SUNNY 1.0 DE 06/86 A 10/88
- SUNNY 1.3 DE 05/82 A 05/89 + 1.3 KOMBI DE 05/82 A 08/90
- SUNNY 1.4 DE 10/88 A 12/90
- SUNNY 1.5 DE 05/82 A 09/88 + 1.5 KOMBI DE 09/83 A 05/86
- SUNNY 1.6 1.6COUPE DE 08/86 A 05/89
- SUNNY 1.6I 1.6I COUPE DE 10/88 A 09/90
- Lockheed/Delphi LP261
- Bendix 552206/552208
- Bosch 986469580
- Ferodo FDB293
- Lucas/TRW GDB288/GDB988
- Quinton Hazell BP229
- Nissan 41060-01A25,41060-01A85,41060-12A25,41060-13A25,41060-13A90,41060-25A25,41060-61A86,41060-62A90,41060-62A92,41060-67A90,41060-89A90,41060-89A91,DA060-13A85
- Nissan 41060-77A91AS Pulsar, carb, 1984-1985 to -0485
- Part number 41060-01A25 was superceded by part number 41060-77A91AS
- Subaru 725191220 725191631 725191990 725193121
- Justy 1984-2003 front
- USA Nissan Pulsar 1984 2BBL carbureted
- Nissan 41060 77 A91AS
- WAGNER PD233/ZD233 or MX275, GUARDIAN 61233, MONROE DX275/CX275, AKEBONO ACT275, Brake Best MKD275, Raybestos RPD266M/RPD266/PGD233/RPD233, Centric 10002750, Beck/Arnley 0891243/0871243/0821243/0881243D/0881243M
- 1983 Nissan Pulsar L4 1.6 Liter Carbureted - VIN P
- 1983-1986 Nissan Pulsar NX 1.6 Liter Carbureted
- 1987 Nissan Pulsar NX XE L4 1.6 Liter FI - VIN P (CA16DE)
- 1988-1990 Nissan Pulsar NX
- 1982-1990 Nissan Sentra
- 1984-1985 Nissan Stanza
- 1983 Pulsar 1.6
- http://www.rockauto.com/catalog/x,carcode,1382150,parttype,1000004,EPIsubcategory[235],Front%2BBrake%2BPads,partGroup,14
- BECK/ARNLEY 0821243/0871243/0881243M , GUARDIAN 65275, RAYBESTOS SGD275M/PGD275M/, WAGNER 7155A/D275/ZX275, AC/DELCO 17D275M/18028853, MONROE DX275/MX275/CMX275, AKEBONO ACT275,
- http://www.rockauto.com/catalog/x,carcode,1212758,parttype,1000004,EPIsubcategory[235],Front%2BBrake%2BPads,partGroup,14
- 1989 Sentra 1.6
Nissan Competition
- 41060-H1020 PAD ASSY-Brake FR DS11 AN18 caliper for Long distance driving
- 41060-H1021 PAD ASSY-Brake FR M59S AN18 caliper for Short-medium distance driving
Friction Materials
- FMSI 782-D41
- FMSI 7059 (D41) Nissan, Honda
- FMSI 7039 (D103) Nissan, Honda
- 1976-1982 Cherry
- 1980-1982 Pulsar
- 1970-1974 1200
- 1974-1976 B210
- 1979-1981 Sunny
- 1972-1979 Civic
- 1969-1970 S800
- FMSI 7040 (D104)
- FMSI 7064-D113
Aftermarket Pads
Aftermarket is parts you buy from the parts store, as opposed to sold by the car manufacturer. They can vary from the original manufacturer's specifications in these areas:
- Friction material (asbestos, organic, semi-metallic, ceramic, etc.)
- Friction formula (high-temp, high-friction, low-dust, etc)
- Method of fastening pad to backing plate (rivits, expoxy, etc.)
- Anti-squeal features like a rubberized backing
- Replacement-warning tabs
- Pad surface area^
^Aftermarket pads tend to suppport many models, so have the largest pad. For example B110 and B310 use the same Type D41, but the B110 pad is spec'd at a smaller friction pad, while B310 uses a larger pad. Both will bolt on the other.
D41 Pad
FMSI Type D41 for 58 mm backing plateRockauto.com $5 - $24 * 1971-1973 B110 USA * B110 JDM GL, GX * 1973-1974 Civic USA * 1976-1978 F10 USA * 1979-1982 N10 (Datsun 310) USA * 1978-May 1979 PA10 Stanza GL, GLX * tons of OTHER Datsuns & Nissans including: ** B15 SR16VE ** Y11 SR20VE
Raybestos PGD104 Wearever D41 Bendix D104 Beck/Arnley 0880100D? ACDELCO 17D104 (18028686) ACDELCO ACD39 ACDELCO ACD122 Akebono AK-37 GDB GDB126 Best Brake D104/MKD104
D117 Pad
FMSI Type D117/D113 for backing plate 63.5 mmRockAuto $10 - $26 * 1974-1978 Datsun B-210 USA * 1975-1979 Civic USA * 1977-1979 Datsun 200SX (S10) USA * 1979-1982 Datsun 210 (B310) USA * 1975-1976 Datsun 610 USA * 1975-1977 Datsun 710 USA Raybestos SGD117/PGD117/RPD117 Beck/Arnley 0870944/0820944/0880944D Wearever D103 Bendix D103 ACDELCO 17D117 (18028692) Akebono A-33K MK D1008 KD-29
Specs: Backing plate width: 63.5 mm D117 Backing plate height: 52.2 mm D103 Backing plate height: 54.5 mm thickness (plate + Pad): 13.5 mm to 14.2 mm
D206 Pad
Type D206* 1974-1975 HB210 (A14 powered B210) USA, JDM * Datsun 180K 1973-1975 * PB110 Sunny Excellent 1400 * PB210 Sunny Excellent 1400 -1975.9 * Skyline C10, C110, KC110 (1500, 1600) 1968-1975.9 * Skyline 1800 PC10,KPC110,PC110 1968-1972.8 * Laurel 1800 (C130K,C130) 1972.4-1973.9 * Honda H1300
D103 Pad
Type 103* Skyline BC210 1972 * Bluebird 610 200B 1974-1976 * Bluebird 810 1977 * Bluebird 910 1976-1977 * Sunny 140Y/150Y 1978-1982 * Sylvia S110 1979-1983
Specs Backing plate width: 63.3 mm Backing plate height: 57.2 mm Thicknes (plate + pad): 14.5 mm
D146 Pad
FMSI Type D146* Bluebird 910 (200B/1600/1800) 1980-1983 * Violet 140J/160J 1978-1982 * Stanza Wagon 1600 1978-1982 * Skyline BC211 1977
These look similar to the Sunny pads, but do not have a nub on the top.
Specs Backing plate width: 63.3 mm Backing plate height: 56.4 mm top nub: 0.6 mm Thicknes (plate + pad): 14.5 mm
D37 Pad
FMSI Type D37![]()
Applications * Datsun B310 A14/A15 JDM large brake * Datsun 510 1968-1973 USA * Datsun 610 1973-1974 USA * Datsun 710 1974 USA * Datsun Roadster 2000 1968-1970 USA * Datun 411 1963-1964 USA * Datsun 411 1967 R16 USA * Datsun 180B (610) * Datsun 140J (710) * Nissan Laurel HLC230
Akebono A-1K MK D1000 KD-1 RAYBESTOS RPD37/SGD37/PGD37 Brake Best D37 BECK/ARNLEY 0820118 AXXIS 66D37 ROYALTY MD37
