The Reverse Lamp Switch is the little switch in the transmission that causes the reverse lamps on the back of the 1200 to light up when you put the gearshift lever in the R position.
56-series
32005-K121A Rev Lamp B110 $33.70 USD FS4W56L replaced 32005-21101 COMP-SWITCH REVERSE LAMP replaced 32005-K1214 COMP-SWITCH REVERSE LAMP replaced 32005-K1201 COMP-SWITCH REVERSE LAMP replaced 32005-H5000 COMP-SWITCH REVERSE LAMP Also used as 4TH-gear switch
32010-G1651 -8910 B120 FSW56A replaced 32005-21101 SWITCH ASSY-REVERSE LAMP
60-series
32005-K102A Switch Rev Lamp $36.47 USD FS5W60L, FS5W60A replaced 32005-K1002
