WARNING: Wire colors can vary by year, model and country. Please double-check the wiring in your Datsun 1200 before connecting parts according to this article. You don't want to burn something up! Use a voltmeter or test light to confirm the circuit behavior.
Contents[hide] |
B110
High-Res 1971 Intro Diagram. JDM and Australia is probably the same except for the headlight switch.
UK 1200 nearly the same as USA, same wire colors too
for manual transmission
1971 USA, same as or very close to JDM
USA 1973 Manual Transmission
CAUTION: Very different from 1972-1972, and from non-USA
B120
Australia
1978 Australia 1200 ute
3 parts each 656 x 1280
Total size 1968 x 1280
Other RHD
Differences between 1978 Australia and 1978 other RHD
Horn "Low" is optional in Australia * standard for other RHD countries.
Transmission switches * Australia: Spade connectors for Back-up lamp switch * Other RHD has Round multi-connector to: ** Spade connectors for Top Gear switch ** Spade connectors for Back-up lamp switch
Other RHD has: * T/O Cut Solenoid * Vacuum Cut Solenoid * Speedometer has speed switch and attached SW amplifier * Heater is optional * Dimmer dash illumination switch ** Has usual six-connector rectangular connector ** Has additional 1-spade wire for Twist Control ** Two-position: Normal and Dim (not continously variable)
LHD
Left-hand Drive 1978 B120 has these differences from RHD: * Cigarette lighter is not illuminated
Otherwise may be identical as far as colors and wires, but presumably the length of many wires differ.
B122
Late-model Sunny Truck from October 1989
B210 Early RHD (Australia?):
