Datsun 1200 was equipped with a round-port inlet manifold. USA got one with accessories fitings, while Japan, Canada and other countries got a plain intake manifold. For other A-series engines, manifolds differ by country and year.
Datsun 1200
Datsun 1200 was equpped with a round-port, dry, original bolt-patten inlet manifold. It looks like the Datsun 1000 manifold but it slanted 2 degrees different. USA manifolds came with extra fittings, while Japan, Canada and other countries got a plain manifold.
Plain: only fittings are for PCV and one port (seen here with a plug)
New bolt-pattern VS original bolt-pattern
Datsun 1200 is always the original bolt pattern.
Intake and exhaust manifold are bolted together:
A12 GX Engine
See A12 GX Engine for details on the GX intake manifold.
- 14003-H3901 MANIFOLD-INTAKE A12,AUTO 0771-
- 14003-H3900 MANIFOLD-INTAKE A12,MANUAL 0771-
- 14003-H1901 MANIFOLD-INTAKE A12,CALIFORNIA 0671-0771
- 14003-H1900 MANIFOLD-INTAKE A12 EXHAUST -0571
- 14003-H1000 MANIFOLD-INTAKE A12 CRANK [Canada]
INTAKE GASKET
- 14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD
- 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD
OTHER
- 14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD
- 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD
- 08216-62210 STUD FIXING CARBURETOR 4
- 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 2
- 01111-00032 BOLT 1
- 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 3
- 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
- 08915-13810 WASHER-LOCK 5
- 14037-32200 YOKE-MANIFOLD 4
Oval Port Comparo
Gasket
Round Port, No water ports, Original bolt pattern
- 14035-18000 B10, B110, B210 A12S early, B210 A12S V late, B310 A12S V -7909 (Select Use)
- 14035-18010 B310 A12S V -7909 (Select Use)
GX - Large Oval Port, Wet Intake
- 14035-H2300 A12GX, A12T
Round Port, No water ports, New bolt pattern (both patterns?)
- 14035-H7200 B310 A14S Van -7909 (Select Use)
- 14035-H7210 B310 A14S Van -7909 (Select Use)
- 14035-H7400 B310 Van 7910- (Select Use), supercedes H7200
- 14035-H7410 B310 Van 7910- (Select Use), supercedes H7210
Round Port, Water Ports, New bolt pattern
- 14035-H8501 B310 A12S S,K -8010, A13 8011-
Oval Port, Water Ports, New bolt pattern
- 14035-H8901 B310 A14S S,K + AT -8010, A15S 8011-
Medium Oval Port, EFI Head
- 14035-H9201 B310 A14E -8010, A15E
B210 Early
From the Nov 1976 JDM catalog
*Single Carb * Gasket 14035-18000 14003-H1900 M/T w/o Mastervac 14003-H5101 A/T, M/T with Mastervac
*Twin Carb (A12T) * Gasket 14035-H2300 14003-H5731 A12T 14003-H5732 A12T from '75-3 ^H5731
B210 Late
From the B210 Japanese Domestic Model parts catalog (Jul 1978)
A12
14003-H5101 V
A12S
14003-H7400 S,K
A14
14003-H7200 V 14003-H7860 V
A14T
14003-M2450 A14T
B120
- 14003-H1000 MANIFOLD-intake 1971-1974 [old bolt pattern, D-shaped heater gasket]
- 14003-H5111 MANIFOLD-INTAKE 7510-7803 [old bolt pattern, triangular heater gasket]
- 14003-H8110 MANIFOLD-INTAKE 7804-7907
- 14003-G2561 MANIFOLD-INTAKE 7908-8109 [new bolt pattern, D-shaped heater gasket]
- 14003-G2600 MANIFOLD-INTAKE 8110-8910
- 14001-95W00 MANIFOLD-INTAKE 8910- [late-model 6-bolt carb]
Late Sunny Truck
1989-up B122 manifold: Round-port, wet style, new bolt-pattern, with extended-length carb flange.
New-bolt pattern (like an A14):
B310
USA A14/A15 FEDERAL (except California)
- 14003-H9500 MANIFOLD-INTAKE FED 0880- 0 14003-H9950 [1981-1982 small oval]
- 14003-H9950 MANIFOLD-INTAKE FED -0780 2 14003-H9900
- 14003-H9900 MANIFOLD-INTAKE FED 0879- 0 14003-H9100
- 14003-H9100 MANIFOLD-INTAKE FED (EXC KFU) 0878-0779 0 14003-H7200
- 14003-H7202 MANIFOLD-INTAKE FED (EXC KFU) replaced 14003-H7200
- 14003-H7200 MANIFOLD-INTAKE FED (EXC KFU)
FED KFU (A14 round port)
wet & dry types
- 14003-H7400 MANIFOLD-INTAKE FED(KFU) -0778
- 14003-H9160 MANIFOLD-INTAKE FED(KFU) replaced 14003-H7400
USA CALIFORNIA A14/A15
- 14003-H9160 MANIFOLD-INTAKE CAL A14 replaced 14003-H7400
- 14003-H7400 MANIFOLD-INTAKE CAL A14 -0778
- 14003-H9550 MANIFOLD-INTAKE CAL 0678-0779
- 14003-H9950 MANIFOLD-INTAKE CAL -0780 superceeded 14003-H9900
- 14003-H9900 MANIFOLD-INTAKE CAL 0879- replaced 14003-H9160
CANADA A14/A15
- 14003-H7400 MANIFOLD-INTAKE A14 CAN -0778
- 14003-H9160 MANIFOLD-INTAKE CAN 0879-
Custom/Aftermarket Manifold Suppliers
- TWM
- Lynx single (PN M041) and dual (PN M042) DCOE/DHLA manifolds, dual SU manifold (M137)
- TWM Induction intakes, carbs, etc
- Ramflo
- Lynx manifolds & Kay C (KC) adapter, Ramflo filters and Weber carbs
- Ram intake downdraft manifold
- Cannon Industries
- 5611 208th Ave S.W.
- Lynnwood, WA 98036
- Redline Auto (Australia) makes single and dual DCOE manifolds and linkage, for A12 through A15 motors.
- Same parts are available from Holley (Australia).
- Stewart Wilkins GX manifold - only $260 AUD
- eBay
CUSTOM MANIFOLDS
Steel manifold is difficult to make. You need to form steel to ovals to round to tapered out. When used with a turbocharger, Steel won't break and would be ported to your cylinder head.
- "Mammi Motors" on the Peninsula in Victoria (40 mins from Melbourne).
- Ph: (03) 5977 7973
- Steel manifold for maybe $250 for Weber 40s or 45s. ** They also do nice head work for around $300 which includes porting and 1600 exhaust valves
Aftermarket manifold finish quality can be really poor so check for flat flanges, port overlap. See Jason's Weber page.
Single Sidedraughts
Cannon
Warneford
Lynx
- M041 MANIF DATSUN 1200 1 X DCOE/DHLA
- M042 MANIF DATSUN 1200 2 X HS4 SU
- M137 MANIF DATSUN 1200 2 X HS4 SU
D1000
Round port, pre-emission (no provision for PCV valve) for SU or Hitachi sidedraughts.
D1200 SU
Lynx D1200 for A12 engine, twin SU HS4 pattern, round port with crossover design.
Does this exist?
D1200 Single
Lynx D1200 for A12 engine, single-DCOE pattern, round port with crossover design.
Crossover puts the runners in firing order.
D1200 Twin
Lynx D1200 (model M041) Round port for Twin Weber DCOE 40 style.
SSS
Oval port twin DCOE manifold marked 'SSS'. This is not for the Datsun 1200 SSS model which had round port heads.
