Rubber parts
Revision as of 09:21, 3 July 2011; view current revision
Category: Body
Datsun 1200 weatherstripping, pedal pads, door seals, window seals
For part numbers, click the photos.
Body Panels
Fender/gaurd/wing to body.
Pedals
Pedals: rubber part numbers
  • Brake pedal - manual
  • Brake pedal - automatic
  • Clutch pedal
Clutch
RHD clutch lever boot
Gearshift
Interior shift boot (large)
Transmission shifter seal boot (small)
Windscreen
Windscreen (windshield/front window)
Doors
Door bump stop
Door Ventilator (Wing window/quarter window)
(click to view main article)
Door Glass Rubber (click to view main article)
weatherstripping (click to view main article)
ドア ウェザー ストリップ ドア インサイド モール
Bonnet
Bonnet (hood) bump stops
Trunk
Boot (trunk) seal. Is same material as 510. Possibly 510 part will fit with trimming.
  • 84810-H1001 WEATHERSTRIP-TRUNK LID Sedan $53.73 USD
    • superseded 84810-H1800 WEAHERSTRIP-TRUNK LID Coupe
Suppliers
Note that 1200 fans around the world purchase new seals from Scott's mail order.
  • Nissan dealer has most rubber parts still available
Australia
New Zealand
  • NZ - Para Rubber bulb seal for quarter windows
United States
  • Trim Lok "Trim Seal" I use the largest tube (3/4",19mm) mounted in the "A" position. This is the same trim used around the door openings of the 1200. Good for the 2-dr sedan pop-out windows.
  • California: Too Intense Restoration often has genuine Nissan seals.
Discussion
discussion in main forum
