Engine Troubleshooting Overview
Revision as of 09:13, 12 December 2006; view current revision
Introduction
Trouble shooting is only a process of elimination and provided the procedure is carried out correctly and systematically an accurate diagnosis of the trouble can be made in the minimum amount of time.
For an internal combustion engine to run there are three basis requirements, these are ignition, fuel and compression. There are other factors of course, but as a rule an engines failure to start can be attributed to a fault in one or more of these three systems.
The most likely cause of an engine wont start issue is an ignition or electrical failure first followed by fuel, with mechanical or compression failure the least common.
Before getting into ignition troubleshooting it is worth checking, is there fuel in the fuel tank? If yes begin the ignition/electrical diagnosis.
Ignition and Electrical Systems checks
Switch on the ignition and check for warning lamp illumination.100_2749_small.jpg
Operate the starter switch and check that the starter rotates the engine at a steady speed.
Switch on the headlamps and check for good light intensity. 100_2751_small.jpg
Should the lamps not illuminate or the starter motor not turn the engine, carry out the following action:
(a) Remove the battery terminals and clean both terminals and posts. Refit the terminals and tighten firmly but not excessively.
(b) Check that the earth lead from the battery to the engine and body frame is not broken and that the connections are clean and secure.
(c) Check that the lead from the battery to the starter motor or starter solenoid is intact and with a clean and secure connection.
(d) Where necessary carry out repairs to (b) and (c)
