With A-series gearboxes getting less common, you might consider a transmission swap. With the Nissan 71-Series Transmission, we have lots of choices included 6-speeds and stumpy gearboxes that use stock tailshafts. Or non-Nissan brand transmissions can be swapped in behind the A12.
Tunnel Consideration
A standard Datsun 1200 has a small central tunnel, limiting the gearboxes that will fit. However, automatic-equipped Datsun 1200s have a very large that will accomodate most gearboxes and still allow the factory heater to work.
See main article: Tunnel
Adapter Plate
How about a good-old fashioned adapter plate? This is how it was done when I was younger. They swapped any kind of gearbox to any kind of engine.
An adapter plate bolts to the engine, then using a 2nd set of bolt holes the tranmission is bolted to it.
Cut & Shut
Cut-and-shut is where the front part of the new transmission is cut off, and a cut-off part of an A-series transmission is welded to it.
