See:
- Engine block for Datsun 1200
- Block Comparison for late vs early A-series, A12/A13/A14/A15
B110 RAW LIST 11010-H2300 ASSY-BLOCK,CYLINDER 11010-H1000 ASSY-BLOCK CYLINDER 12293-18001 BOLT FIXING BEARING CAP 1 11019-32200 PLUG-WELCH 44 CAM BEARING 00933-13500 PLUG-WELCH 35 CORE HOLE 01648-00084 PLUG-WELCH 35 CORE HOLE 00933-15000 PLUG-WELCH 50 CORE HOLE 11021-13200 PLUG-TAPER 12.7 OIL GALLERY 11024-K0100 PLUG-TAPER 12.7 OIL GALLERY 00933-20650 PLUG-TAPER 6 OIL GALLERY 01647-00011 PLUG-TAPER 6 OIL GALLERY 11046-73402 DOWEL-TIMING 5 FRONT COVER 11023-32200 DOWEL-TIMING 5 FRONT COVER 30412-21000 DOWEL-TIMING 9.5 CASE LOCATING 08213-82810 STUD-FIXING FUEL PUMP 08213-84810 STUD FIXING WATER PUMP 08213-84510 STUD FIXING WATER PUMP 08223-81610 STUD FIXING ENGINE MOUNTING BRACKET 12279-18000 SEAL-OIL CRANKSHAFT REAR 12279-18010 SEAL-OIL CRANKSHAFT REAR (NDK) 12279-H1000 SEAL-OIL CRANKSHAFT REAR (NOK) 21045-18000 PIPE-SUCTION WATER PUMP 08931-30410 PLUG-TAPER THRED WATER DRAIN 11037-H1000 NET-STEEL CRANK CASE 11038-H1000 PLATE-BAFFLE CRANK CASE 08310-61214 SCREW-MACHINE 10005-H1000 SLINGER-ENGINE FRONT 08110-8161B BOLT-HEX M8 08110-81611 BOLT-HEX M8
