Special factory Datsun service tools
Special Tool - Engine, Clutch, Transmission
ST093-50000 SET-C TOOL 2 ST110-80000 REAMER SET-VALVE GUIDE FOR ENGINE 3 ST113-20000 DRIFT-VALVE GUIDE FOR ENGINE 4 ST116-70000 CUTTER SET-VALVE SEAT FOR ENGINE 5 ST130-40000 PRESS STAND-PISTON PIN FOR ENGINE 6 ST161-10000 DRIFT-CAMSHAFT BEARING FOR ENGINE 7 ST166-80000 PULLER-PILOT BUSH FOR ENGINE 8 ST206-10000 BAR-CLUTCH ALIGNING FOR CLUTCH 9 ST223-50000 DRIFT-MAIN SHAFT BEARING FOR TRANSMIS 10 ST230-30000 PRESS STAND-COUNTER SHAFT BEARING FOR 11 ST230-50000 HEIGHT GAUGE-COUNTER GEAR FOR TRANSMIS 12 ST235-20000 PUNCH-SOLID FOR TRANSMISSION 13 ST236-20000 GUIDE-FORKE ROD FOR TRANSMISSION 14 ST238-20000 PLATE-ADAPTER SETTING FOR TRANSMISSION 15 ST227-30000 PULLER-BEARING FOR TRANSMISSION
Special Tool - Differential, Front Axle, Rear Axle
16 ST306-00000 DRIFT-DRIVE PINION BEARING FOR DIFFEREN 17 ST311-20000 GAUGE-DRIVE PINION ARANGEMENT F 18 ST315-40000 WRENCH-DRIVE PINION FLANGE FOR DIFFEREN 19 ST325-00000 WEIGHT-SIDE BEARING ADJUST FOR DIFFEREN 20 ST332-20000 DRIFT-SIDE BEARING FOR DIFFERENCIAL 21 ST311-90000 GAUGE-PRELORD FOR DIFFERENCIAL 22 ST312-30000 ASSY-DUMMY SHAFT FOR DIFFERENCIAL 23 ST353-10000 DRIFT-FRONT WHEEL HUB BRG OUTER RACE F 24 ST355-50000 GUIDE-GRAND PACKING FOR AXLE 25 ST371-30000 PULLER-REAR AXLE SHAFT BEARING FOR 26 ST382-70000 PRESS STAND-REAR AXLE SHAFT BEARING FOR 27 ST367-20000 REPLACER SET-TRANSVERS LINK BUSHING FOR 28 ST271-90000 PULLER-STEERING LINKAGE JOINT FOR AX
