Carburetor Part Numbers
Revision as of 02:01, 10 January 2012; view current revision
Categories: Fuel System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Carburetor
Crank
1 16010-H1601 ASSY-CARBURETOR (HITACHI DCG A12 CRANK 1070- 2 16010-H1600
1 16010-H1602 ASSY-CARBURETOR (HITACHI DCG A12 CRANK 0771- 2 16010-H1601
1 16010-H1600 ASSY-CARBURETOR (HITACHI) A12 CRANK
2 16118-H1000 ASSY-CHAMBER THROTTLE A12 CRANK
3 16145-91460 SPRING IDLER ADJUST SCREW A12 CRANK
4 16145-50000 SPRING THROTTLE ADJUST SCREW A12 CRANK
5 16129-14811 SCREW-THROTTLE ADJUST A12 CRANK 2 16129-25715
5 16129-25715 SCREW THROTTLE ADJUST A12 CRANK
6 16144-B0815 SCREW IDLE ADJUST A12 CRANK
7 16082-18010 PLATE-ADJUST A12 CRANK
8 16065-10620 SCREW 6D A12 CRANK
8 16065-H1010 SCREW 6D A12 CRANK 2 16065-H1010
9 16029-18010 WASHER 6D A12 CRANK
10 16061-18010 FLOAT A12 CRANK
11 16066-18010 SHAFT FLOAT A12 CRANK
12 16101-H1000 VALVE NEEDLE A12 CRANK
13 16094-10400 WASHER 10D (2) A12 CRANK
14 16098-25710 FILTER A12 CRANK
15 16025-H1000 TUBE EMULSION (P) A12 CRANK
16 16026-25710 TUBE EMULSION (S) A12 CRANK
16 16026-B0810 TUBE EMULSION (S) A12 CRANK 2 16026-25710
17 16171-25710 WEIGHT INJECTOR A12 CRANK
18 16033-18017 JET-MAIN #92(2000M) OP A12
18 16034-18016 JET-MAIN #86(4000M) OP A12
18 16034-19915 JET MAIN #98 A12 CRANK
19 16135-33815 JET MAIN #135 A12 CRANK
20 16050-18010 BLEED MAIN AIR #80 (2) A12 CRANK
21 16204-08000 BLEED MAIN AIR #100 A12 CRANK
22 16213-08000 BLEED MAIN AIR #220 A12 CRANK
22 16052-85060 BLEED MAIN AIR #200 A12 CRANK 2 16213-08000
23 16055-14811 JET SLOW #43 A12 CRANK -1173 3
24 16054-B0810 JET SLOW #50 A12 CRANK
25 16059-14810 VALVE POWER #60 A12 CRANK
26 16455-H1000 KIT-GASKET A12 CRANK
26 16455-H6200 KIT-GASKET A12 CRANK 2 16455-H1000
27 16465-H1000 SCREW & WASHER ETE KIT (A) A12 CRANK
28 16475-H1000 SCREW & WASHER ETE KIT (B) A12 CRANK
29 16134-18010 LEVER THROTTLE A12 CRANK
30 16116-18010 SLEEVE A12 CRANK
31 16133-H1000 LEVER STARTING A12 CRANK
32 16084-58000 WASHER A12 CRANK
32 16084-22010 WASHER A12 CRANK 2 16084-58000
33 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H A12 CRANK 2 16160-H1000
33 16160-H1000 SPRING THROTTLE RETURN A12 CRANK
34 16141-18010 ROD CONNECTING A12 CRANK
35 16272-36710 PLATE DRAIN (2) A12 CRANK
36 16151-H1000 PISTON A12 CRANK
37 16148-H1000 SPRING PISTON RETURN A12 CRANK
38 16307-04000 COVER PUMP A12 CRANK
39 16302-18010 LEVER PUMP A12 CRANK
40 16305-19915 SHAFT PUMP LEVER A12 CRANK
41 16143-18010 ROD PUMP A12 CRANK
42 16011-H1600 ASSY-CHOKE CHAMBER A12 CRANK
42 16011-H1601 ASSY-CHOKE CHAMBER A12 CRANK 2 16011-H1600
43 16248-H1000 ROD CHOKE CONNECTING A12 CRANK
44 16161-H1000 HANGER SPRING A12 CRANK
44 16161-H1001 HANGER-SPRING A12 CRANK 0970- 2 16161-H1000
45 16155-B0815 ARM THROTTLE WIRE A12 CRANK
46 16165-H1600 ARM CHOKE WIRE A12 CRANK
47 XX010-H1925 KIT-REPAIR A A12 CRANK 2 X6010-H1925
47 16009-H1910 KIT-REPAIR A CARBURETOR A12 CRANK 2 XX010-H1925
47 16009-H7000 KIT-REPAIR A CARBURETOR A12 CRANK 2 16009-H1910
47 16009-H6200 KIT-REPAIR A CARBURETOR A12 CRANK 2 16009-H7000
47 X6010-H1925 KIT-REPAIR A A12 CRANK
48 16009-H1911 KIT-REPAIR B CARBURETOR A12 CRANK 2 XX010-H1926
48 X6010-H1926 KIT-REPAIR B A12 CRANK
48 XX010-H1926 KIT-REPAIR B A12 CRANK 2 X6010-H1926
Exhaust
To May 1971 with Manual Choke. From June 1971 see DCH Carburetor
1 16010-H1901 ASSY-CARBURETOR A12 EXHAUST & EVAPO 2 16010-H1900
1 16010-H1902 ASSY-CARBURETOR HITACHI DCG306-3A A12 EXHAUST & EVAPO 1070- 2 16010-H1901, 16010-H1602
1 16010-H1900 ASSY-CARBURETOR A12 EXHAUST & EVAPO
2 16118-H1910 ASSY-CHAMBER FLOAT A12 EXHAUST & EVAPO
3 16145-91460 SPRING-IDLE ADJUST SCREW A12 EXHAUST & EVAPO
4 16145-50000 SPRING-THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO
5 16129-14811 SCREW-THROTTLE ADJUST A12 EXHAUST & EVAPO 2 16129-25715
5 16129-25715 SCREW-THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO
5 16455-H6200 SET-GASKET A12 EXHAUST & EVAPO 2 16455-H1000
6 16144-B0815 SCREW-IDLE ADJUST SCREW A12 EXHAUST & EVAPO
7 16082-18010 PLATE-ADJUST THROTTLE A12 EXHAUST & EVAPO
8 16133-H1000 LEVER-STARTING A12 EXHAUST & EVAPO
9 16116-18010 SLEEVE A12 EXHAUST & EVAPO
10 16134-H1910 LEVER-THROTTLE A12 EXHAUST & EVAPO
11 16236-H1910 LEVER (A) A12 EXHAUST & EVAPO
12 16116-H1910 SLEEVE (A) A12 EXHAUST & EVAPO
13 16249-H1910 LEVER A12 EXHAUST & EVAPO
14 16034-19915 JET-MAIN #98 A12 EXHAUST & EVAPO
15 16135-33815 JET-MAIN #135 A12 EXHAUST & EVAPO
16 16272-36710 PLUG-DRAIN (2) A12 EXHAUST & EVAPO
17 16059-14810 VALVE-POWER #60 A12 EXHAUST & EVAPO
18 16148-H1000 SPRING-PISTON RETURN A12 EXHAUST & EVAPO
19 16151-H1000 PISTON A12 EXHAUST & EVAPO
20 16025-H1000 TUBE-EMULSION P A12 EXHAUST & EVAPO
21 16026-25710 TUBE-EMULSION S A12 EXHAUST & EVAPO
21 16026-B0810 TUBE-EMULSION S A12 EXHAUST & EVAPO 2 16026-25710
22 16050-18010 BLEED-MAIN AIR #80 (2) A12 EXHAUST & EVAPO
23 16171-25710 WEIGHT-INJECTOR A12 EXHAUST & EVAPO
24 16055-14811 JET-SLOW #43 A12 EXHAUST & EVAPO
25 16054-B0810 JET-SLOW #50 A12 EXHAUST & EVAPO
26 16011-H1600 ASSY-CHOKE CHAMBER A12 EXHAUST & EVAPO
26 16011-H1601 ASSY-CHOKE CHAMBER A12 EXHAUST & EVAPO 2 16011-H1600
27 16204-08000 BLEED-SLOW AIR #100 A12 EXHAUST & EVAPO
28 16213-08000 BLEED-SLOW AIR #220 A12 EXHAUST & EVAPO
28 16052-85060 BLEED-SLOW AIR #200 A12 EXHAUST & EVAPO 1 16213-08000
29 16098-25710 FILTER A12 EXHAUST & EVAPO
30 16101-H1000 VALVE-NEEDLE A12 EXHAUST & EVAPO
31 16066-18010 SHAFT-FLOAT A12 EXHAUST & EVAPO
32 16061-18010 FLOAT A12 EXHAUST & EVAPO
33 16307-04000 COVER-PUMP A12 EXHAUST & EVAPO
34 16302-H1910 LEVER-PUMP A12 EXHAUST & EVAPO
35 16305-19915 SHAFT-PUMP LEVER A12 EXHAUST & EVAPO
36 16452-H1000 SPRING-PUMP LEVER A12 EXHAUST & EVAPO
37 16453-H1000 WASHER (T=2MM) A12 EXHAUST & EVAPO
38 16155-H1910 ARM-THROTTLE A12 EXHAUST & EVAPO
39 16161-H1911 HANGER-SPRING A12 EXHAUST & EVAPO 1170- 2 16161-H1910
39 16161-H1910 HANGER-SPRING A12 EXHAUST & EVAPO
40 16165-H1600 ARM-CHOKE WIRE A12 EXHAUST & EVAPO
41 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H A12 EXHAUST & EVAPO 1070- 2 16160-H1000
41 16160-H1000 SPRING-THROTTLE RETURN A12 EXHAUST & EVAPO
42 16248-H1000 ROD-CHOKE CONNECTOR A12 EXHAUST & EVAPO
43 16143-H1910 ROD-PUMP A12 EXHAUST & EVAPO
44 16141-18010 ROD-CONNECTOR A12 EXHAUST & EVAPO
45 16262-H1910 DIAPHRAGM-SURVO A12 EXHAUST & EVAPO
46 16455-H1000 SET-GASKET A12 EXHAUST & EVAPO
46 16455-H6200 SET-GASKET A12 EXHAUST & EVAPO 2 16455-H1000
47 16475-H1910 SCREW & WASHER SET B A12 EXHAUST & EVAPO
48 16465-H1000 SCREW & WASHER SET A A12 EXHAUST & EVAPO
49 16009-H1910 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO
49 16009-H7000 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H1910
49 16009-H6200 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H7000
50 16455-H1000 SET-GASKET A12 EXHAUST & EVAPO
51 16307-04000 PUMP-COVER A12 EXHAUST & EVAPO
52 16009-H1911 KIT-REPAIR B CARBURETOR A12 EXHAUST & EVAPO
53 16009-H7000 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H1910
53 16009-H6200 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H7000
53 16009-H1910 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO
54 16475-H1910 SCREW & WASHER SET B A12 EXHAUST & EVAPO
55 16151-H1000 PISTON A12 EXHAUST & EVAPO
56 16129-25715 THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO
56 16129-14811 THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO 2 16129-25715
57 16144-B0815 IDLE ADJUST SCREW A12 EXHAUST & EVAPO
58 16098-25710 FILTER A12 EXHAUST & EVAPO
59 16101-H1000 NEEDLE VALVE A12 EXHAUST & EVAPO
60 16066-18010 FLOAT SHAFT A12 EXHAUST & EVAPO
61 16453-H1000 WASHER A12 EXHAUST & EVAPO
