Wheel bearings
Revision as of 07:32, 10 January 2012; view current revision
Categories: Front Axle And Front Suspension | Brakes
[hide]
Front
Bearings for drum hub and disc hub are the same.
RockAuto.com
Outer
42mm O.D. Type 30302
  • 40215-H1000 ASS'Y-BEARING-front wheel, outer
  • 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER from 0570
  • 40215-18000 ASSY-BEARING FRONT WHEEL OUTER to 0470
  • BCA/Timken/National 30302
  • Taper Bearing Assembly
    • Bore=0.5906"
    • Outer Diameter=1.6535"
    • Width=0.561"
    • Cone Length=0.5118"
    • Cup Length=0.4331"
    • Cone Radius=0.06"
  • 1957-1967 Fiat 500/600
  • 1976-1978 Datsun F10
  • 1981-1995 Suzuki, various models
Inner
52 mm O.D. Type 30305
  • 32351-M5100 ASS'Y-BEARING-front wheel, inner
    • Part 40210-H1000 is superseded by 32351-M5100
    • 40210-H1000 ASSY-BEARING FRONT WHEEL INNER from 0570
    • 40210-18000 ASSY-BEARING FRONT WHEEL INNER to 0470
Aftermarket
  • SKF BR30205
  • Beck/Arnley 051-3809 0513809
  • Timken 30205M
  • BCA/NATIONAL 30205
  • 000720030205, 0009813705, 0059819105, 0059819205, 0069813605, 025933047, 0259330470, 0857591700, 11040, 1450481, 1522731, 183682, 18524, 26799930, 290062202, 31422345289, 33121451188, 40210H1000, 6601141, 7703090268, 7730205, 89459, 90005900200, 906100005, 9760030205, 9760930205, 9985014, A710X1200ABA, AK2508906, C5NN7N044A, C5NN7N047A, C5NN7N048A, E5TZ7065A, N035160, S08333075, T3090268, T7730205
  • Datsun B10, B110, B210, B310, 520/521, 620 -1974, N10
  • 1971-1993 Mazda, various models
  • 1971-1983 Renault, various models
  • 1971-1972 Peugeot 304
  • 1987-1994 Subaru Justy
  • N10 transmission bearing MT.F5 A-series
  • 1979-1982 Chevrolet/Isuzu Luv Pickup
  • 1990-1992 Daihatsu Rocky
  • 1974-1991 Chrysler/Mitsubishi, various models
  • 1989-1993 Dodge Truck D250/D350/W350
  • 1984-1987 Hyundai, various models
  • 1950-1965 Volkswagen
  • 1958-1961 Simca, various models
  • 1954-1959 Panhard Dyna
  • 1960-1962 Panhard PL-17
  • 1991-2010 Mitsubishi, various models
  • Cone radius=0.0394"
    • Standout=0.1280"
    • Outside diameter=2.0470"
    • Inside diameter=0.9840"
    • Cup radius=0.0394"
    • Cup length=0.5118"
    • Cone length=0.5906";
    • Bore=0.9843"
    • Outer Diameter=2.0472"
    • Width=0.6398"
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
