60-Series Transmission
Revision as of 23:58, 29 December 2006; view current revision
Categories: Transmission | Drivetrain Modifications
The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-series transmission. The 60-series can handle the torque from A14 and A15 engines. They came in to varieties:
  • 60L for A-series engine (1978 B310 Sunny)
  • 60A for A-series engien (1979-up Sunnys)
Note that this series may be available for other engine types, so make sure you get one to match the A-series engine.
For an overview of 5-speeds in general, see: 5-speeds. Comparos, Ratio info, etc.
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this section originally in the old Tech Section)
How do I install a 5 speed Sunny box?
60a 5-speed swap Notes
  • the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
  • There are two different types of 60A rear engine mounts (transmission mounts).
    6946.jpg rear engine mounts
    8131.jpg custom engine mounts <li>The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
    7474.jpg pic
  • The reverse-light switch is right where the Datsun 1200 chassis x-member mount is. You can remove the switch and plug the hole. A spare A12 engine-block drain plug fits (from the side of the engine block). Some say you can beat the chassis out to make room
  • The stock Datsun 1200 flywheel and clutch can be used
