A brake booster was first fitted to Datsun 1200 starting in October 1989. The Datsun 1200 is so light it does not take much leg pressure to stop. The booster means that less exertion is needed by the driver to press the pedal. The booster doesn't make the brakes stop quicker, but instead lets a small person press as hard as a muscleman.
Also see: Brake Booster Swaps
Parts
- 47210-G1500 BOOSTER ASSY-BRAKE 9810-
- superceded by 47210-G1510
- 47212-D0100 PACKING-BOOSTER [4-bolt boster-to-firewall gasket]
- 47471-G1500 HOSE-BOOSTER [from booster to check valve]
- 47478-03B00 VALVE ASSY-CHECK
- 47472-95W00 HOSE-BOOSTER [from check valve to intake manifold]
- 47475-H8504 CONNECTOR-BOOSTER HOSE [intake manifold fitting]
It uses this Master Cylinder, which uniquely has two horizontally aligned bolt holes. Other Datsun 1200 master cylinder have two bolts in vertical alignment.
- 46010-G1500 CYLINDER ASSY-BRAKE MASTER 8910-
