Swapping your front drum brakes to disc brakes is a worthwile easy upgrade.
If your 1200 has all-drum brakes, take note that disc brakes are:
- easier to work on
- More resistant to fading -- safer after repeated stops (they dissipate heat far better)
Swapping 1200 drums for discs is easy if you obtain the entire strut/spring/brake assemblies for both sides. Just unbolt, bolt in the new assembly and bleed the front brakes.
Why not bolt the disc brakes onto the drum-brake struts? Because the drum-brake struts do not have caliper mounting brackets.
Details
<please add>
