Transmission Swaps
Revision as of 03:43, 23 January 2012; view current revision
Category: Drivetrain Modifications
With A-series gearboxes getting less common, you might consider a transmission swap. With the Nissan 71-Series Transmission, we have lots of choices include 6-speed gearboxes and stumpy gearboxes that use stock tailshafts. Or non-Nissan brand transmissions can be swapped in behind the A12.
[hide]
When comptemplating a swap to another type of transmission, the following parts are needed:
  • Transmission of choice
  • Clutch disc, pressure plate, release bearing, and pilot bushing for the end of the crankshaft. It is recommended that you buy all new. They can be reused, but only recommended if they are in known good condition.
  • Driveshaft (tailshaft/propeller shaft) to fit both your Differential and the transmission
  • Rear mount (gearbox mount)
  • Slave cylinder and slave push rod to match the new transmission
  • Release arm and release bearing sleeve to match the new transmission
  • Speedometer cable to match the new transmission and your speedometer
If converting an automatic-equipped car to manual transmission you need:
  • The brake/clutch pedal assembly, complete with all hardware and springs, from the same model car you have now
  • Flywheel & clutch pilot bushing
See main article: Manual transmission conversion
If you have cable clutch and the new transmission requires a hydraulic clutch linkage:
  • Clutch Master cylinder and Slave cylinder. The cylinders may be bought new, as they are inexpensive and you know they will not be worn out.
  • Hydraulic hard line. A pre-made section of brake hard line may be bought and bent to fit.
  • Hydraulic flexible hose
Considerations:
  • Length of transmission
  • Shifter location
  • Speedometer cable. Is it on the same side? If on the passenger side, you might need a longer cable.
Common Swaps
Common swaps include:
For information on common swaps see: 5-Speeds
This article will focus on swaps adapting non-A-series tranmissions to fit.
Tunnel Consideration
A standard Datsun 1200 has a small central tunnel, limiting the gearboxes that will fit. However, automatic-equipped Datsun 1200s have a very large tunnel that will accomodate most gearboxes and still allow the factory heater to work.
See main article: Tunnel
Adapter Plate
How about a good-old fashioned adapter plate? This is how it was done when I was younger. They swapped any kind of gearbox to any kind of engine.
An adapter plate bolts to the engine, then using a 2nd set of bolt holes the tranmission is bolted to it.
here is a Hewland adapter plate:
Cut & Shut
Cut-and-shut is where the front part of the new transmission is cut off, and a cut-off part of an A-series transmission is welded to it.
Just cut the bellhousing and weld on a fragment of A-series bell housing, then machine the input shaft smaller.
Silva S15 6-Speed gearbox modified for use with A12 engine
As with any adaption, aligning the adapter is critical. It must be:
  • parallel to the transmission and rear engine faces
  • Centered exactly on the crank/input centerlines
The tolerance is very low, so this must be a precision fitting to avoid clutch vibration and early gearbox wear.
Milling Method
  1. Cut the front case of transmission approximately
  2. Remove front case
  3. Mill the cut parallel to the face of the case
  4. Repeat for A-series bell-fragment
  5. Weld a circular plate to the case
  6. Center the bell fragment on the plate and weld it
Centering can be done with careful use of dividers and precision measuring.
Shaft Alignment Method
Make a shaft to go in an old A-series engine block where the crankshaft would go. Weld a perpendicular flange on the end. It must be very accurately at right angle to the shaft.
NOTE: photos of L-series engine. But A-series will be similar
Remove the front case from the transmission.
Insert into the engine block and bolt the transmission front case to it. This needs to be very secure so that no play is magnified down along the shaft. Precision is very important in gearbox alignment.
Cut the transmission case aproximately as much off as needed. You could do it with stationary grinding wheel while rotating the case on the shaft.
Bolt the A-series fragment to the block too
Rotate the case appropriately and weld together.
Result: 6-speed front case modified with different type of bellhousing pattern.
