SR engine swap
Revision as of 09:16, 21 February 2012; view current revision
Category: Engine Modifications
The SR20 can bolt-in to a Datsun 1200 without cutting the firewall, though it's easier with an original automatic-equpped car (which has a bigger central tunnel). The 1989 SR series is considered to be the replacement for the 1981 CA Engine based primarily on NVH improvements. It is heavier and bulkier than the CA series, but the SR20 puts out more HP than the CA18 or CA20 engines. In most Australia states, 2-liter is the largest normal engine swap into 1200, so the SR20 naturally aspirated is the ultimate capacity swap. In North America where there are no laws limiting capacity swaps, the KA24 is a more popular swap due to the larger CCs, higher horsepower and higher availability.
  • SR18Di was made for a while (1990-1993), but has less HP than a GA16DE engine -- see GA Engine Swap
  • SR18DE made 125HP, but is much heavier and bulkier than CA18DE 131 HP
  • SR20Di only 122 HP (single-point Fuel Injection)
  • SR20VE is the hot one, with NEO VVL variable camshaft timing and lift. Unfortunately it was only available in FWD vehicles.
RWD vs. FWD block
RWD SRs:
  • Nissan Silvia S13, S14, S15 (240SX) 1990-2002
  • NIssan 180SX
Crossmember
SR can use the same mounts as L-series or Z-series.
Here is a 1200 crossmember, horns removed and low profile horns fabricated:
Transmissions
Colors
Red Top: S13/180SX/Bluebird/Pulsar 1989–1994, Garrett T25G turbo
Black Top: S13/180SX 1994–1998, Garrett T25G turbo
Black Top: S14 1994–1998,  VTC, Garrett T28
Black Top: S15 1999–2002,  VTC, Garrett T28, Coil-pack, 6-speed
Silver Top: Avenir 1995–2001
Silver Top: R'nessa 1997-2001
Forum
Discussion: AFRacer's journal of SR20DET Swap into Left-hand-drive 1200
Sources
Japan Market
R10   	SR20D
S13   	SR20D
U12   	SR20D
WU12  	SR20D
WU12  	SR20D
C23   	SR20DE
C24   	SR20DE
M11   	SR20DE
M12   	SR20DE
N30   	SR20DE
P10   	SR20DE
P10E  	SR20DE
P11   	SR20DE
P11E  	SR20DE
R11   	SR20DE
RB14  	SR20DE
RS13  	SR20DE
S14   	SR20DE
S15   	SR20DE
U13   	SR20DE
U14   	SR20DE
V10   	SR20DE
W10   	SR20DE
W11   	SR20DE
WP11  	SR20DE
M12   	SR20DET
N14   	SR20DET
N30   	SR20DET
RS13  	SR20DET
S14   	SR20DET
S15   	SR20DET
U13   	SR20DET
W10   	SR20DET
W11   	SR20DET
S13   	SR20DT
U12   	SR20DT
P11   	SR20VE
P12   	SR20VE
U14   	SR20VE
WP11  	SR20VE
T30   	SR20VET
North America
FWD - distributor on back of head, no VVT
B13   	J/SR20DE
B13   	U/SR20DE
B14X  	SR20DE
B14U  	SR20DE
B15U  	SR20DE
S13 - no VVT
S14/S15 - VVT (cam bulge), DET has twin slope cam cover
FWD - no VVT, distributor on back of head
RWD - distributor on left side of head at front
S14/S15 DET - no distributor (COP ignition)
FWD - Nissan Sentra
S13 1994–1998 Red Top SR20DE - plug wires and no cam bulge (no VVT)
S13 1994–1998 Red Top SR20DET COP, no VVT
S13 1994–1998 Black Top
S14/S15 1994–2002 Black Top
S14 SR20DE - cam bulge
S14 SR20DET - cam bulge w/twin sloping cam cover
COP ignition - no plug wires
S15 SR20DE - plug wires & distributor
Same as S14
S15 SR20DET - COP (no distributor) twin slope-cover
Same as S14
Intake Manifold
S13 - underslung plenum
S14/S15 - plenum on top
Ignition
S14 SR20DE VVT - distributor on left side of head on front
S14 SR20DET - COP, no plug wires
Richard Swap
Some guys at Ozdat swapped an SR20DE into a 1200, costs were $1400 for the engine swap part, $2000 total including the car.
http://www.youtube.com/watch?v=3m7U4qwIGaM
Click each photo for large photo and discussions.
985.jpg 1121.jpg 1504.jpg 2769.jpg 3936.jpg 4541.jpg 4661.jpg 4662.jpg 4663.jpg 4664.jpg 4665.jpg 4666.jpg 4667.jpg 4668.jpg 4802.jpg 4806.jpg 5288.jpg 5289.jpg 5290.jpg 6021.jpg 6027.jpg 6736.jpg 6981.jpg 6982.jpg 8047.jpg 8679.jpg
