R145
Revision as of 10:17, 23 February 2012; view current revision
Category: Differential
Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear suspension cradle which contained the differential and the entire suspension less the struts.
Standard type
N14, N15 Pulsar
N30 9710-0107 R'nessa
B15, M12, G10, N15, RB14, W11, B13, N14
M12, JU30, P12, U30, VW11, W11
Coupling Type
C24 with hydraulic coupling (C24 was FWD normally)
M12 with hydraulic coupling 0105-
K11 March with hydraulic coupling
T30 X-Trail with electric coupling
Murano USA Z50 electric coupling
Electric Coupled
N14 Pulsar
including RNN14 GTiR
Sources
Z50 Murano USA
N14, N15 Pulsar
B14, B15 Sunny
RB14
C24 9907- Serena (IRS post-vanette)
K11 9911-0010 March CG10DE+CGA3DE
M12 9811-0105 Prairie Liberty
P12 0101- Primera
T30 0010 to 2007 X-Trail
JU30 9911- Besara
U30 9806- Presage
VW11 9809- Expert エキスパート
W11 9809- Avenir
T30
380
38300-8H500 FINAL DRIVE ASSY
38761-8H500 COUPLING ASSY-ELECTRIC
38421-4N200 CASE-DIFFERENTIAL
 C24,K11,M12,P12,T30,W11
38100-4N500 GEAR SET-FINAL DRIVE 37/15=2.466
38310-8H500 CARRIER COMPL-GEAR
38331-8H500 COVER-COUPLING
K11 March
38760-4N210 COUPLING ASSY-HYDRAULIC
Case
 CASE (CARRIER COMPL-GEAR)
38310-8H500 [electric coupling]
 T30
38310-4N500
 C24, M12, JU30, P12, U30, VW11, W11
38311-20E00
 N30 Rnessa
 JU30 9911-0108 KA24DE+YD25DDT
38310-4N500
  JU30 0108- QR25DE
38311-71Y00/38311-71Y02
 B13, B15, M12, G10, N14, N15, RB14, W11
Gearset
2.466
3.357
3.692
3.700
38100-CA000 GEAR SET-FINAL DRIVE 37/15=2.466 $617 USD
 C24,K11,M12,P12,T30,VW11,W11,JU30,U30
38100-11E65 48/13=3.692
 B15, G10, U30
38100-10E60 GEAR SET-FINAL DRIVE 47/14=3.357
 M12, N30, W11, U13
38100-03G10 GEAR SET-FINAL DRIVE 37/10=3.700
 B13, B14, N14, N15, RB14
LSD
Both Nissan and Cusco sell rear LSD
38760
38411-20R21 COUPLING ASSY-VISCOUS $584 USD
* superseded 38411-20R14
* N14 JDM
* M11 USA Axxess 0189- *4WD.KA24E.SGL.FA (R200?)
Cusco
MZ TYPE-RS No. LSD684 1.5 way Subaru BP/BL (2003-2009 Legacy/Liberty)
MZ 1-way
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling, when not powered, allows the rear diff to free-wheel (FWD mode).
When fully powered, the propeller shaft powers the diff as normal.
The coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT)
T30 JDM X-Trail GT
Hydraulic Coupling
38760M
* K11 March
38760-4N215 COUPLING ASSY-HYDRAULIC
* C24 Serena
* M12 Prairie Liberty
* P12 Primera
* VW11V Expert エキスパート
Gasket
Gear carrier (main housing) gasket
38320 GASKET-GEAR CARRIER
38353-U3000 $5 USD
* USA.S130+910+M10+M11
* JDM.M10+M11+B12+U12+910+U12+P10+C31+F30+C31+N13+R30+S12
999MP-A7007P K11 [w/fluid coupling] [split gaskets]
*C8320-00330 $22 Silicon Gasket
38320-01G03
38320-01G02 Gasket Gear Carrier $28 USD
38320-01G00
* R200/R180/R160/R145?
* JDM.N14,N15,B13,B14,B15,C22,C23,D21,D22,F23,E24,M12,VE24,WE24,
  G10,JU30,U30,N30,R20,R30,R33,RB14,S14,W11,W30,A31,C33,C34,
  R20,U13,WD21
