Comparison of Spark Curve parts for 1978 B210 North American models. It includes six different curves for CAL, CAN, FED and AT versus 4-speed (MT) versus 5-speed (FU) models.
Distributor
1978 B210 (all use A14 engine) CAN MT (D4A7-02) 0°/70mmHg-15°/300mmHg 0°/750-10°/2400 RPM CAN AT (D4A7-03) 0°/70-6.5°/300 0°/750-10°/2400 CAL MT (D4F5-03) 0°/105-15°/390 0°/550-14°/2300 FED MT (D4F5-03) "" GFU MT (D4F7-01) 0°/80-14.5°/330 0°/550-14°/2400 CAL AT (D4F5-05) 0°/105-9°/300 0°/550-14°/2300 FED AT (D4F6-03) 0°/170-6.5°/300 0°/550-14°/2300
Initial Timing
1978 B210 A14 USA MT 10°/700 RPM CAN MT 10°/700 USA FU 5°/700 CAN AT 10°/650 CAL AT 10°/650 FED AT 8°/650
Advance Parts
1978 B210 FED MT 22108-H7300 SHAFT ASSY 22109-A5500 WEIGHT GOVERNOR 22110-H7301 SET GOVERNOR SPRING 22301-H7360 VACUUM CONTROL ASSY
1978 B210 FED AT 22108-H7300 22109-A5500 22110-H7301 22301-H7205 VACUUM CONTROL ASSY
GFU 22108-H7300 22109-A5500 22110-H7780 22301-H7680 VACUUM CONTROL ASSY
CAL MT 22108-H7300 22109-A5500 22110-H7301 22301-H7360
CAL AT 22108-H7300 22109-A5500 22110-H7301 22301-H7365
CAN MT 22108-M5600 22109-A5500 ??? 22110-H7601 22301-M2361 <2> 22301-H7201
CAN AT 22108-M5600 22109-A5500 ??? 22110-H7601 ?????-?????
Mechanical Advance
1978 B210 CAN MT (D4A7-02) 0°/750-10°/2400 RPM CAN AT (D4A7-03) "" GFU MT (D4F7-01) 0°/550-14°/2400 CAL MT (D4F5-03) 0°/550-14°/2300 FED MT (D4F5-03) "" CAL AT (D4F5-05) "" FED AT (D4F6-03) ""
0°/550-14°/2300 22108-H7300 SHAFT ASSY 22109-A5500 WEIGHT GOVERNOR 22110-H7301 SET GOVERNOR SPRING
0°/550-14°/2400 22108-H7300 22109-A5500 22110-H7780 [heavier spring]
0°/750-10°/2400 22108-M5600 22109-A5500 ??? 22110-H7601
Vacuum Advance
mmHg CAN MT (D4A7-02) 0°/70-15°/300 CAN AT (D4A7-03) 0°/70-6.5°/300 GFU MT (D4F7-01) 0°/80-14.5°/330 CAL AT (D4F5-05) 0°/105-9°/300 CAL MT (D4F5-03) 0°/105-15°/390 FED MT (D4F5-03) "" FED AT (D4F6-03) 0°/170-6.5°/300
VACUUM CONTROL ASSY 22301-H7360 0°/105-15°/390 $71 USD 22301-H7205 0°/170-6.5°/300 $63 USD 22301-H7680 0°/80-14.5°/330 $93 USD 22301-M2361 0°/70-15°/300 [superceded by 22301-H7680] 22301-H7365 0°/105-9°/300 $75 USD ?????-????? 0°/70-6.5°/300
others 22301-H6200 $62 USD 22301-H9100 $60 USD 22301-H7200 [superceded by 22301-H9100] 22301-H8300 $51 USD 22301-H9501 [superseded by 22301-H9801] DUAL 22301-H9801 $73 USD DUAL 22301-H9806 $61 USD 22301-H8700 $66 USD 22301-H9160 $60 USD 22301-H9100 $60 USD 22301-H7106 NLA 22301-H9106 $51 USD
Looks same 22301-33M01 1983-1985 * 22301-33M02 * 22301-33M04 * GM 88924909 22301-32M01 1983-1985 22301-D3300 1984 22301-D2100 1983-1984 22301-10W21 1983-1984 * 22301-10W22 22301-N4700 1977-1977 22301-06W03 1981-1982 22310-D1706 1982 22301-W8800 1980 * 22301-W8801 22301-N4200 1975-1978 22301-18R05 1985-1986 22301-47W01 1981 22301-N3602 1974 22301-07W03 1982-1983 * 22301-07W05 22301-B9800 1978-1980 * 22301-B9905 * 22301-C6001 22310-20W21 1983-1985 * 22301-20W22 22301-23M00 1982 DUAL * 22301-24M00 22301-23M07 1983 DUAL 22301-34M00 1983-1985 * 22301-34M01 22301-D2106 1983-1984 22301-D1701 1982 22301-N5906 1977-1979 22301-W8905 1980 Honda 30104-PE1-840 1986-1987 Honda 30104-663-791 1978
