Also see:
Part Numbers Index Main articles for usage, photos, cross-reference: Fender (guard/wing) Hood (bonnet) Mirrors Core Support Battery
Sunny Truck
Paint & Wax - see Paint Part Numbers Side Mirror - see Truck Side Mirror Part Numbers
1 62500 SUPPORT ASSY-RADIATOR CORE 62500-H1000 -7803 62500-H1800 7804-8910 62500-95W00 8910- 2 62511 SUPPORT-RADIATOR CORE,UPPER 62512-H1000 -7803 62510-H1800 7804-8910 62510-G1265 8910- 3 62515 STAY-HOOD LOCK 62522-H1001 4 62610 APRON-FRONT PANEL 62612-H1000 -7803 62612-H1800 7804-8910 62612-H1800 8910- SB.-DX 62612-H1000 8910- LB+SB.DX 5 62610A SCREW 77720-89908 SCREW-with plain washer -8007 4 08363-61238 8008- 4 6 62610B NUT 63140-78500 -8007 4 01241-00011 2 0 01241-00011 8008-8503, 8910- 4 7 62528 COVER ASSY-COOLING HOLE 62524-H1000 -8503, 8911- F/COLD ZONE 8 08513-51012 SCREW 4 9 63100 FENDER-FRONT,RH 63100-H1002 63100-H1003 -7803 63100-G1030 7804-8012 63100-G1230 4 0 63100-G1230 8101-8408 63100-G1231 2 0 63100-G1231 8408-8910 シンクロカ 63100-G1060 8910- 10 63101 FENDER-FRONT,LH 63100-H1002 63101-H1003 -7803 63101-G1030 7804-8012 63101-G1230 4 0 63101-G1230 8101-8408 63101-G1231 2 0 63101-G1231 8408-8910 シンクロカ 63101-G1060 8910- 11 63100A SCREW-FENDER 77720-89908 SCREW-with plain washer -8503 16 01436-00093 8910- 12 64100 HOODLEDGE ASSY-RH 64100-H1000 64100-H3100 7110-7206 64100-H7000 7207- 64100-G1650 -8012 64100-G1950 2 0 64100-G1950 8101-8910 F4100-G1960 2 0 F4100-95W00 9810- 13 64101 HOODLEDGE ASSY-LH 64101-H1000 -7206 64101-H7000 7207- 64101-G1600 7510-8012 64100-G1950 2 0 64101-G1900 8101-8910 F4100-G1960 2 0 F4101-95W00 9810- 14 64151 REINFORCEMENT-HOODLEDGE,RH 64118-H1000 15 64152 REINFORCEMENT-HOODLEDGE,LH 64119-H1000 16 65100 HOOD 65100-H1000 65100-G1600 -8102 65100-G1900 2 0 65100-G1900 8103-8503 65100-G1902 8504- 17,18,19,20 see Cowl 20 64135 BRACKET-BATTERY SUPPORT 24426-H1001 24426-G1600 8504-8901 24421-G1900 2 0 22421-G1900 8901-
HOOD HINGE
1 65400-H1001 HINGE ASS'Y-hood (R.H.) 2 65401-H1001 HINGE ASS'Y-hood (L.H.) Fixing hinge to bracket 3 65409-H1000 PIN-hinge 2 4 08915-13810 WASHER-lock 2 5 01121-00121 BOLT-special 4 < 01436-00111 -8504 01436-00073 BOLT 4 8504- 6 66510-H1000 ROD-hood support -8503 66510-G1200 ROD-hood support 8504- 7 65512-H2500 GROMMET-hood rod 8 65514-H1000 CLAMP-hood rod
Sedan
1 62500-H1000 ASSY-SUPPORT,RADIATOR CORE SEDAN 2 62512-H1000 RAIL-SUPPORT,RADIATOR CORE, UPPER SEDAN 3 62522-H1001 STAY-HOOD CATCH SEDAN 4 62612-H1000 PANEL-APRON,FRONT SEDAN 5 63100-H1900 ASSY-FENDER,FRONT,RH SEDAN 6 63101-H1900 ASSY-FENDER,FRONT,LH SEDAN 7 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) SEDAN 8 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) SEDAN 9 63810-H1001 SEALER-COWL TOP(L=250MM) (2) SEDAN 0670- 9 63810-H1000 SEALER-COWL TOP(L=200MM) (2) SEDAN 10 63811-H1000 SEALER-FRONT FENDER (2) SEDAN 11 64100-H1000 ASSY-HOODLEDGE,RH SEDAN 11 64100-H3100 ASSY-HOODLEDGE.R.H. SEDAN 1271- 11 64100-H7000 ASSY-HOODLEDGE,RH SEDAN 0772- 12 64101-H1000 ASSY-HOODLEDGE,LH SEDAN 12 64101-H7000 ASSY-HOODLEDGE,LH SEDAN 0772- 13 24420-21401 FRAME-BATTERY,FIX SEDAN 13 24420-J0600 FRAME-BATTERY,FIX SEDAN 14 24440-21000 ROD-BATTERY,FIX (2) SEDAN 14 24422-18001 ROD-BATTERY,FIX (2) SEDAN 14 24438-21000 ROD-BATTERY,FIX (2) SEDAN 15 24427-H1000 STAY-BATTERY BRACKET SEDAN 15 24427-H1001 STAY-BATTERY BRACKET (2) SEDAN 16 77720-89910 BOLT-SPECIAL (3) SEDAN 16 77720-89913 BOLT-SPECIAL (3) SEDAN 17 24428-19102 TRAY-BATTERY SEDAN 17 24428-89920 TRAY-BATTERY SEDAN 1170- 18 08911-10610 NUT-HEX (2) SEDAN 19 08915-43610 WASHER-PLAIN (2) SEDAN 19 08915-4361A WASHER-PLAIN (2) SEDAN 20 65100-H1000 ASSY-PANEL,HOOD SEDAN 20 F5100-G1902 ASSY-PANEL,HOOD SEDAN 21 65400-H1001 ASSY-HINGE,HOOD,RH SEDAN 22 65401-H1001 ASSY-HINGE,HOOD,LH SEDAN 23 65409-H1000 PIN-HINGE,TO BRACKET (2) SEDAN 65409-80W00 PIN-HINGE,TO BRACKET (2) SEDAN 24 08915-13810 WASHER-LOCK,HINGE TO BRACKET (2) SEDAN 25 08110-61210 BOLT-HEX,HINGE TO HOOD (4) SEDAN 26 08915-43610 WASHER-PLAIN,HINGE TO HOOD (4) SEDAN 27 08915-13610 WASHER-LOCK,HINGE TO HOOD (4) SEDAN 28 65510-H1000 ROD-HOOD SUPPORT SEDAN 28 65510-G1200 ROD-HOOD SUPPORT SEDAN 29 65512-H1000 GROMMET-ROD,HOOD SEDAN 29 65512-H2500 GROMMET-ROD,HOOD SEDAN 1070- 30 65514-H1000 CLAMP-ROD,HOOD SEDAN 30 65514-55W00 CLAMP-ROD,HOOD SEDAN 31 96302-H1900 ASSY-DOOR MIRROR LH SEDAN 96301-H5950 ASSY-DOOR MIRROR RH SEDAN 31 96302-H5950 ASSY-DOOR MIRROR LH SEDAN 32 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) SEDAN
Coupe
1 63100-H1900 ASSY-FRONT FENDER RH COUPE 2 63101-H1900 ASSY-FRONT FENDER LH COUPE 3 01111-00022 BOLT-HEX WITH WASHER FENDER FIX 1 (16) COUPE 4 08915-43610 WASHER-PLAIN FENDER FIX 1 (16) COUPE 5 63810-H1001 SEALER-COWL TOP (2) COUPE 0670- 2 63810-H1000 5 63810-H1000 SEALER-COWL TOP (2) COUPE 6 63811-H1000 SEALER-FRONT FENDER (2) COUPE 7 64100-H1000 ASSY-HOODLEDGE RH COUPE 7 64100-H3100 ASSY-HOODLEDGE R.H. COUPE 1271- 5 64100-H1000 7 64100-H7000 ASSY-HOODLEDGE RH COUPE 0772- 0 64100-H3100 8 64101-H1000 ASSY-HOODLEDGE LH COUPE 8 64101-H7000 ASSY-HOODLEDGE LH COUPE 0772- 0 64101-H1000 9 24420-J0600 FRAME-BATTERY FIX COUPE 2 24420-21401 9 24420-21401 FRAME-BATTERY FIX COUPE 10 24440-21000 ROD-BATTERY FIX C (2) COUPE 2 24438-21000 10 24438-21000 ROD-BATTERY FIX A (NOT ADOPTED (2) COUPE 11 24427-H1000 STAY-BATTERY BRACKET COUPE 11 24427-H1001 STAY-BATTERY BRACKET (2) COUPE 2 24427-H1000 12 24428-19102 TRAY-BATTERY COUPE 12 24428-89920 TRAY-BATTERY COUPE 1170- 2 24428-19102 13 08911-10610 NUT-HEX M6X1.0 (2) COUPE 14 08915-43610 WASHER-PLAIN M6 (2) COUPE 15 65100-H1000 ASSY-PANEL HOOD COUPE 16 65400-H1001 ASSY-HINGE HOOD RH COUPE 17 65401-H1001 ASSY-HINGE HOOD LH COUPE 18 65409-H1000 PIN-HINGE HOOD HINGE TO BRACKET (2) COUPE 19 08915-13610 WASHER-LOCK M6 HINGE TO BRACKET (2) COUPE 20 08110-61210 BOLT-HEX M6X1.0 HINGE TO HOOD (4) COUPE 21 08915-43610 WASHER-PLAIN M6 HINGE TO HOOD (4) COUPE 22 08915-13610 WASHER-LOCK M6 HINGE TO HOOD (4) COUPE 23 65510-H1000 ROD-HOOD SUPPOUT COUPE 24 65512-H1000 GROMMET-HOOD ROD COUPE 24 65512-H2500 GROMMET-HOOD ROD COUPE 1070- 2 65512-H1000 25 65514-H1000 CLAMP-ROD HOOD COUPE 26 96302-H1900 ASSY-DOOR MIRROR COUPE 27 62845-78500 RUBBER-RADIATOR CORE SUPPORTSIDE (2) COUPE
