Also see:
Part Numbers Index Main article for usage, photos, cross-reference Tailgate Rear Window Fuel Door Vents Bumperettes
Truck
BODY SIDE FITTING 01 78130-G1000 COVER ASS'Y-gas filler 02 77760-89902 BUMPER-rubber, gas filler 2 03 76850-G1001 GRILLE-air outlet (R.H.) 76851-G1001 GRILLE-air outlet (L.H.) 04 08530-71690 SCREW 4 07 76960-H1001 LOCK ASS'Y-gas filler 08 78962-18200 CLIP-seating cylinder lock 09 08310-51014 SCREW-with lock washer 2 <> 08360-51014 10 08915-43510 WASHER-plain 2 11 76916-00100 PLUG-rubber 2
REAR FLOOR FITTING 44 93599-14800 PLUG-floor hole 4 (op.)
Back Window
BACK WINDOW 12 79712-G1000 GLASS-back window (up to '73-8) * 79712-G1200 GLASS-back window (from '73-9) 13 79417-G1000 WEATHERSTRIP-back window 79710 79417-G1001 WEATHERSTRIP-back window (up to '73-8) * 79417-G1201 WEATHERSTRIP-back window (from '73-9) * (79712-G1200) is compatible with the new parts in the set (79714-G1201) 14 79810-G1000 RAIL/PLATE-guard back window 3 08310-61226 SCREW-with washer (fixing guard plate) 6
HOLDFAST-GUARD 93100-G1060 FRAME ASSY-GUARD 7804- 93152-G1060 HOLDFAST-GUARD FRAME 8504- 3 [clip] 93154-G1060 HOLDFAST-GUARD FRAME 8504- 3 [insert] 93156-G1060 HOLDFAST-GUARD FRAME 8504- 3 [bracket] 08110-61610 08110-61225 93158-G1060 HOLDFAST-GUARD FRAME SIDE 8504- 2 08110-82025 BOLT
Tailgate
BACK DOOR PANEL
90100 DOOR-BACK
90100-G1000 GATE ASS'Y-rear
90100-G1600 -7803
90100-G1662 7804-8405 to C/#B122-020551
to C/#GB122-013092
90100-G1661 8405-8910 from C/#B122-020552
from C/#GB122-013093
90100-G1202 8910-
90100B BUMPER RUBBER-TAIL GATE -
90802-G1000 -7603 2 <6,6> 90802-G1001
90802-G1001 7604- 2
08310-62012 SCREW
90100G HOOK-CHAIN 90134-G1000 -8503 R.H. 90135-G1000 -8503 L.H. 90134-G1000 8503- 2
90100J GROMMET 01658-00511 11MMアナヨウ 8504-8910 1 01658-00511 11MMアナヨウ 8910- 2
90410 HINGE ASSY-BACK DOOR,RH 90400-G1000 2 08915-13610-lock WASHER 4 08915-53610-plain WASHER 4 08360-61612 SCREW -8109 4 or 90451A SCREW 01436-00111 8110-8503 4 01436-00073 8504- 4
90880A BOLT 93425-B5000 -8910 2 93425-G1900 8910- 4
90880G HANGER-CHAIN 90815-G1000 -8910 2 90815-G1000 8910- 4
90880S CHAIN SET-REAR GATE 90810-G1001 -8910 <2,0> 90810-G1900 90810-G1930 8910-
BACK DOOR TRIMMING
90900 FINISHER ASSY-BACK DOOR 90805-G1000 COVER-rear gate Short Body < 90805-G1001 90805-G1001 Long & Short Body 90900G GROMMET-SCREW 96706-G1000 -8110 12 67898-U7400 8110-8503 12 67989-U0100 8910- 12 08530-51612 SCREW 12
BACK DOOR LOCK
90502 LOCK ASSY-BACK DOOR 90500-G1024 LOCK ASS'Y-rear gate 2 90500-G1025 -8503 2 <2,0> 90500-01W00 90500-01W00 8504- 2 08360-61612 SCREW 4 08915-13610 WASHER-lock 4 08915-43810 WASHER-plain 4
90616A SPACER-ROD 93896-01W00 2
