Tailgate Part Numbers
Revision as of 06:22, 1 May 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Tailgate
Rear Window
Fuel Door
Vents
Bumperettes
Truck
BODY SIDE FITTING
01 78130-G1000 COVER ASS'Y-gas filler
02 77760-89902 BUMPER-rubber, gas filler 2
03 76850-G1001 GRILLE-air outlet (R.H.)
   76851-G1001 GRILLE-air outlet (L.H.)
04 08530-71690 SCREW 4
07 76960-H1001 LOCK ASS'Y-gas filler
08 78962-18200 CLIP-seating cylinder lock
09 08310-51014 SCREW-with lock washer 2 <> 08360-51014
10 08915-43510 WASHER-plain 2
11 76916-00100 PLUG-rubber 2
Bumperettes
35 85010-G1001 RUBBER ASS'Y-bumper rear (R.H.)
   85011-G1001 RUBBER ASS'Y-bumper rear (L.H.)
Fixing rear bumper rubber
 36 08310-64510 SCREW 2
 37 08915-13610 WASHER-clock 4
 38 08915-43610 WASHER-plain 4
 39 08110-61810 BOLT 2
REAR FLOOR FITTING
44 93599-14800 PLUG-floor hole 4 (op.)
Back Window
BACK WINDOW
12 79712-G1000 GLASS-back window (up to '73-8)
*  79712-G1200 GLASS-back window (from '73-9)
13 79417-G1000 WEATHERSTRIP-back window 79710
   79417-G1001 WEATHERSTRIP-back window (up to '73-8)
*  79417-G1201 WEATHERSTRIP-back window (from '73-9)
* (79712-G1200) is compatible with the new parts in the set (79714-G1201)
14 79810-G1000 RAIL/PLATE-guard back window 3
   08310-61226 SCREW-with washer (fixing guard plate) 6
HOLDFAST-GUARD
93100-G1060 FRAME ASSY-GUARD 7804-
93152-G1060 HOLDFAST-GUARD FRAME 8504- 3 [clip]
93154-G1060 HOLDFAST-GUARD FRAME 8504- 3 [insert]
93156-G1060 HOLDFAST-GUARD FRAME 8504- 3 [bracket]
 08110-61610
 08110-61225
93158-G1060 HOLDFAST-GUARD FRAME SIDE 8504- 2
 08110-82025 BOLT
Tailgate
BACK DOOR PANEL
90100 DOOR-BACK
90100-G1000 GATE ASS'Y-rear
90100-G1600 -7803
90100-G1662 7804-8405 to C/#B122-020551
                          to C/#GB122-013092
90100-G1661 8405-8910 from C/#B122-020552
                      from C/#GB122-013093
90100-G1202 8910-
90100B BUMPER RUBBER-TAIL GATE -
90802-G1000 -7603 2 <6,6> 90802-G1001
90802-G1001 7604- 2
08310-62012 SCREW
08915-13610 WASHER-lock 2 [through 1973]
90100G HOOK-CHAIN
90134-G1000 -8503 R.H.
90135-G1000 -8503 L.H.
90134-G1000 8503- 2
90100J GROMMET
01658-00511 11MMアナヨウ 8504-8910 1
01658-00511 11MMアナヨウ 8910- 2
90410 HINGE ASSY-BACK DOOR,RH
90400-G1000 2
08915-13610-lock WASHER 4
08915-53610-plain WASHER 4
08360-61612 SCREW -8109 4
or
90451A SCREW
01436-00111 8110-8503 4
01436-00073 8504- 4
90880A BOLT
93425-B5000 -8910 2
93425-G1900 8910- 4
90880G HANGER-CHAIN
90815-G1000 -8910 2
90815-G1000 8910- 4
90880S CHAIN SET-REAR GATE
90810-G1001 -8910 <2,0> 90810-G1900
90810-G1930 8910-
Early Chain Set
31 90810-G1001 CHAIN SET-rear gate (op.)
 replaced 90810-G1025 CHAIN ASS'Y-rear gate 2 (op.)
32*93880-B5000 CHAIN ASS'Y-rear gate 2 (op.)
33 93425-B5000 BOLT-special 2
34 98015-G1000 HANGER-rear gate chain 2
BACK DOOR TRIMMING
90900 FINISHER ASSY-BACK DOOR
90805-G1000 COVER-rear gate Short Body < 90805-G1001
90805-G1001 Long & Short Body
90900G GROMMET-SCREW
96706-G1000 -8110 12
67898-U7400 8110-8503 12
67989-U0100 8910- 12
08530-51612 SCREW 12
BACK DOOR LOCK
90502 LOCK ASSY-BACK DOOR
90500-G1024 LOCK ASS'Y-rear gate 2
90500-G1025 -8503 2 <2,0> 90500-01W00
90500-01W00 8504- 2
08360-61612 SCREW 4
08915-13610 WASHER-lock 4
08915-43810 WASHER-plain 4
90616A SPACER-ROD
93896-01W00 2
