Z18ET turbo, Z20, Z22. These crossflow-headed engines are based on the L-series. All install into a 1200 more or less the same way.
Sources
Z16S Z18E/Z18S/Z18T Z20D/Z20S/Z20E Z22S
720 Z16S/Z18S 910 Z16S/Z18S/Z18E/Z18T/Z18P/Z20S/Z20E C120 Z20S C31 Z18P/Z18S/Z20S D21 Z16S/Z18S/Z20S E23 Z18S/Z20S E24 Z20S F22 Z16S/Z20S F30 Z18S H40 Z20D/Z20S R30 Z18S/Z20E S110 Z18E/Z18S/Z18T/Z20E TC22 Z20S W40 Z22S WE24 Z20S
North America
Z18 Turbo
The nice thing about the Z18ET is its a factory setup, legal in most Australia states for a 1200. The downside is how available is it, including the wiring harness?
Swap Notes
Z-series is the 2nd generation of the L-series engine. So oil pans and mounting is the same as fitting an L-series engine.
Also see L-series Engine Swap crossmember, sump sections.
Transmission
Z-series uses the same transmissions as the KA-series engines. The bolt pattern is the same as the L-series but the lean is different.
See Transmission section of KA Engine Swap
Crossmember & Sump
Stock 1200 crossmember may be used unmodified:
Vanette Z-22 sump fits stock crossmember too:
