B110 2-door sedan has large popout side windows, B110 while 2-dr coupe has smaller popout glass.
Both use the same inside handle, but it bolts to the glass in different ways
Hinges are totally different. Sedan uses seperate hinges bolted to the glass, while coupe has them welded to the glass frame.
Sedan
* Tinted * Non-tinted * Laminated or non-laminated
76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T=
Rubber
76802-H1202 WEATHERSTRIP-SIDE WINDOW RH 76803-H1202 WEATHERSTRIP-SIDE WINDOW LH 76922-H1200 WELT-SIDE WINDOW BLACK #698 (2) SEDAN 2 DOOR
B310 also fits with some trimming: B310 83830-H8600 WEATHERSTRIP-SIDE WINDOW RH (BLACK 002G0 $84.53 USD B310 83831-H8600 WEATHERSTRIP-SIDE WINDOW LH (BLACK 002G0 $84.53 USD
B310 weatherstripping can be used for B110 2-dr sedan rear side window weatherstripping. It's almost perfect, but about 1 inch too short for the B110. Surprisingly, the B110 glass is actually larger! The B110 has a window seal that's glued to the outside of the frame, and an inside cover for the door frame. The B310 uses a one-piece seal. Just trim a bit of it off when fitting to the B110.
Hinges & Latch
Hinges - big washer goes under the hinge
Also see Rear Window Part Numbers 76832-H1201 HINGE-SIDE WINDOW (4) SEDAN 2 DOOR 76828-H1200 COVER-SIDE WINDOW HINGE 76870-H1200 ASSY-HANDLE SIDE WINDOW LH 76872-18000 PIN-HANDLE SIDE WINDOW
B310 Handle comparo (does not interchange):
B310 Hinges are identical except for additional tab for hinge cover
Grommet (Finish Nut) Comparo. B310 units do not interchange
B310 grommets can be used if B110 rubber washers are employed
Do B210 hinge covers fit?
