Differential Part Numbers
Revision as of 05:27, 17 June 2012; view current revision
Categories: Powertrain | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
H145 Differential
H165
[hide]
H145 Composite
* 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) B110
* 33800-H1010 ASSY-CARRIER WITH GEAR 39:10(3.900) 0374-0874
1 38310-G0400 COMP-CARRIER GEAR
2 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP
3 38315-G0400 BOLT FIXING DIFF BEARING CAP
4 38100-18000 SET-GEAR, hypoid with pinion (37 T:9 T) B10 Sedan & Coupe
4 38100-18100 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van
4 38100-H0700 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van
4 38100-15400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T
4 38100-G0400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T (from '67-Nov)
4 38100-H1000 SET-GEAR & PINION HYPOID B110 39:10T Sedan,Coupe
4 38100-H1100 SET-GEAR & PINION HYPOID B110 37:9T Van
5 38102-G0300 BOLT-DRIVE GEAR
6 38103-G0400 STRAP-LOCK BOLT
7 38421-G0500 CASE DIFFERENTIAL
8 38423-18000 GEAR-SIDE DIFF BEVEL
9 38424-18000 WASHER-THRUST SIDE GEAR T=0.76 MM
9 38424-18001 WASHER-THRUST SIDE GEAR T=0.81 MM
9 38424-18002 WASHER-THRUST SIDE GEAR T=0.86 MM
9 38424-18003 WASHER-THRUST SIDE GEAR FOR SERVICE T=0.
9 38424-18004 WASHER-THRUST SIDE GEAR FOR SERVICE T=0.
9 38424-18005 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18006 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18007 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18008 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18009 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18010 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18011 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18012 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18013 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18014 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18015 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
9 38424-18016 WASHER-THRUST SIDE GEAR FOR SERVICE T=1.
10 38425-18000	MATE-PINION DIFF BEVEL
11 38426-18000 WASHER-THRUST PINION MATE
12 38427-18000 SHAFT-PINION MATE
13 38428-G0400 PIN-LOCK DIFF PINION
14 38440-H1000 ASSY-BEARING DIFF SIDE
* superseded 38440-18000 ASSY-BEARING DIFF SIDE
15 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05
15 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07
15 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10
15 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20
15 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50
16 38120-18000 ASSY-BEARING DRIVE PINION REAR
17 38140-18000 ASSY-BEARING DRIVE PINION FRONT
18 38165-H1000 SPACER-DRIVE PINION BEARING
18 38165-H1001 SPACER-DRIVE PINION BEARING 0374-
19 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74
19 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77
19 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80
19 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86
19 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92
19 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83
19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89
19 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95
19 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98
19 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01
19 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04
19 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07
19 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10
19 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13
19 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16
19 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19
19 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22
19 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25
20 38189-18000 SEAL-OIL DRIVE PINION
21 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER
21 38210-18000 ASSY-FLANGE COMPANION
22 38215-01300 WASHER-PLAIN -0274
23 38216-H1000 NUT-DRIVE PINION 0374-
23 38216-18000 NUT-DRIVE PINION
24 38320-18010 GASKET-GEAR CARRIER
25 08915-13810 WASHER-LOCK
26 08911-20810 NUT
Sunny Truck
The H165 was used all years of the 1200 Truck.
1 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900)
2 38310-G0400 COMP-CARRIER GEAR
3 38315-G0400 BOLT FIXING DIFF BEARING CAP (4)
4 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP (4)
5 38100-H1000 SET-GEAR & PINION HYPOID 39:10
6 38102-G0300 BOLT-DRIVE GEAR (8)
7 38103-G0400 STRAP-LOCK BOLT (4)
8 38421-G0500 CASE DIFFERENTIAL
9 38423-18000 GEAR-SIDE DIFF BEVEL (2)
10 38424-18000 WASHER-THRUST SIDE GEAR (0)
10 38424-18001 WASHER-THRUST SIDE GEAR (0)
10 38424-18002 WASHER-THRUST SIDE GEAR (0)
11 38425-18000 MATE-PINION DIFF BEVEL (2)
12 38426-18000 WASHER-THRUST PINION MATE (2)
13 38427-18000 SHAFT-PINION MATE
14 38428-G0400 PIN-LOCK DIFF PINION
15 38440-H1000 ASSY-BEARING DIFF SIDE (2) 0772- 2 38440-18000
15 38440-18000 ASSY-BEARING DIFF SIDE (2)
16 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 (0)
16 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 (0)
16 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 (0)
16 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 (0)
16 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 (0)
17 38120-18000 ASSY-BEARING DRIVE PINION REAR
18 38140-18000 ASSY-BEARING DRIVE PINION FRONT
19 38165-H1000 SPACER-DRIVE PINION BEARING
20 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 (0)
20 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 (0)
20 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 (0)
20 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 (0)
20 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 (0)
20 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 (0)
20 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 (0)
20 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 (0)
20 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 (0)
20 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 (0)
20 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 (0)
20 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 (0)
20 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 (0)
20 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 (0)
20 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 (0)
20 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 (0)
20 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 (0)
20 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 (0)
21 38189-18000 SEAL-OIL DRIVE PINION
22 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER FOR SERVICE
22 38210-18000 ASSY-FLANGE COMPANION
23 38215-01300 WASHER-PLASN
24 38216-18000 NUT-DRIVE PINION
25 38320-18010 GASKET-GEAR CARRIER
26 08915-13810 WASHER-LOCK (8)
27 08911-20810 NUT (8)
