Also see:
Part Numbers Index Main article for usage, photos, cross-reference Fuel Pump
1 17010-H1926 ASSY-PUMP FUEL A12 17010-H1900 1 17010-H1900 ASSY-PUMP FUEL A12 2 17065-13210 ASSY-VALVE FUEL PUMP (2) A12 3 17061-50000 GASKET-VALVE FUEL PUMP (2) A12 4 17072-01300 RETAINER-VALVE FUEL PUMP A12 5 17075-13210 SCREW-RETAINER (2) A12 6 17082-18010 CAP-BODY UPPER A12 7 17076-18010 DIAPHRAGM-AIR CHAMBER A12 8 17089-13210 SCREW-CAP & BODY SET (6) A12 9 17090-32200 WASHER-SPRING CAP & BODY SET (6) A12 10 17020-85060 SPRING-ROCKER ARM A12 11 17053-18010 ASSY-DIAPHRAGM A12 11 17053-M0100 ASSY-DIAPHRAGM A12 2 17053-18010 12 17048-18010 SEAL-OIL A12 13 17047-18010 RETAINER-OIL SEAL A12 14 17052-18010 SPRING-DIAPHRAGM A12 15 17010-H1902 ASSY-FUEL PUMP A12 0670- 2 17010-H1900 15 17010-H1903 ASSY-FUEL PUMP A12 1071-0873 32 17010-H1902 15 17010-H1904 ASSY-FUEL PUMP A12 0973- 2 17010-H1903 16 17076-13211 GASKET A12 17 17065-13210 VALVE (2) A12 18 17061-50000 GASKET-VALVE (2) A12 19 17103-M0800 CONNECTOR-INLET A12 20 17103-M0801 CONNECTOR-OUTLET A12 21 17013-H2310 COMP-BODY LOWER A12 21 17013-H2315 COMP-BODY LOWER A12 1071- 21 17013-M2000 COMP-BODY LOWER A12 2 17013-H2315 22 17020-85060 SPRING-ROCKER ARM A12 23 17053-32201 ASSY-DIAPHRAGM A12 24 17048-13910 SEAL-OIL A12 25 17047-13911 RETAINER-OIL SEAL A12 26 17052-37010 SPRING-DIAPHRAGM A12 27 17075-M0100 SCREW (2) A12 1071- 27 17075-13210 SCREW (2) A12 28 17089-13210 SCREW 1 (11) A12 28 17089-M0100 SCREW 1 (11) A12 1071- 29 17090-32200 WASHER-SPRING 1 (11) A12 30 08915-13810 WASHER-LOCK M8 (2) A12 31 08911-10810 NUT-HEX M8 (2) A12 32 00915-41510 WASHER-PLAIN 5/16 (2) A12 33 17099-21002 GASKET-FUEL PUMP (2) A12 34 16420-21000 SPACER-FUEL PUMP A12 34 16420-21001 SPACER-FUEL PUMP A12 2 16420-21000 35 08120-61210 BOLT-HEX M6 (2) A12 36 08915-13610 WASHER-SPRING M6 (2) A12 37 08723-11400 CLAMP-FUEL TUBE (4) A12 -370 0
