The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-series transmission. The 60-series can handle the torque from A14 and A15 engines. They came in to varieties:
- 60L for A-series engine (1978 B310 Sunny)
- 60A for A-series engien (1979-up Sunnys)
Note that this series may be available for other engine types, so make sure you get one to match the A-series engine.
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this section originally in the old Tech Section)
How do I install a 5 speed Sunny box?
60a 5-speed swap Notes
- the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
- There are two different types of 60A rear engine mounts (transmission mounts).
- <li>One type of 60a mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
Stock 1200 mount
Stock 1200 mount
Stock 1200 mount
mount</li> </li> <li>This type bolts from the bottom.
60a rear engine mount
Just use a u-shaped flat steel adapter, with long bolts and spacers.
60a adapter Put together, it looks like this:
pic or
pic
also see: this one
... or make a more sophisticated mount which doesn't need long bolts or spacers:
60a adapter
60a adapter </li>
rear engine mounts
custom engine mounts <li>The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
pic
- The reverse-light switch is right where the Datsun 1200 chassis x-member mount is. You can remove the switch and plug the hole. A spare A12 engine-block drain plug fits (from the side of the engine block). Some say you can beat the chassis out to make room
- The stock Datsun 1200 flywheel and clutch can be used
