PCV
Revision as of 18:31, 23 July 2012; view current revision
Positive Crankcase Ventilation (PCV) was the very first of the emission controls. It aims to prevent the crankcase from dumping fumes right into the atmosphere. This is a good system, and can actually help power and fuel economy. Before 1964, cars had a 'breather pipe' that led from the block down to the underside of the car. Normal blowby gases were thus simply vented to the air. Worse yet, when the piston rings became worn, a visible trail of smoke could be seen eminating from the bottom of the car. Not only did it pollute, but didn't smell good either.
[hide]
Black (lower) hose is the main PCV hose. On the manifold end it connects to the PCV valve. The other end goes to the engine block breather pipe.
Nissan calls its PVC system the "Crankcase Emission Control System".
The PCV system consists of three components:
  1. Simple vacuum-operated valve connected to the intake manifold
  2. crankcase breather hoses:
    • from engine block to the air cleaner
    • from rocker cover to the air cleaner
Fumes are thus routed to either 1) air cleaner when engine speeds are high and so able to 'suck' the fumes in or 2) intake manifold when idling where vacuum is high and so opens the valve slightly and pulls the fumes out of the crankcase. This is where the efficiency comes in. Since at idle the pistons are operating under low vacuum, the PCV valve equalizes the forces in the crankcase, hence less oil is sucked into the cylinders at idle.
Race cars are often required to use an oil/vapor seperator instead of, or in addition to, the PCV valve. The main purpose of this racing requirement is not to increase performance, but to control oil spills onto the race track surface.
CAUTIONS
As part of your Tune-up, replace the PCV valve if it:
  • oil-soaked or crusted with sludge (sometimes it can be cleaned with ether spray or carb cleaner). The valve inside should open and close when you shake it back and forth
  • Has a broken spring. The valve inside should close at rest, even if you hold it straight
Same as all Datsun (L/A/VG/U/R/CA/Z/E/J), many Nissan (including GA) and Subaru 1998-2002 2.5.
PCV Valve, from $4.00 - $7.50. Available everywhere
  • PCV Valve: FRAM FV263 $1.73, BECK/ARNLEY 0450031 $2.24
Infiniti 1993 - 1997 J30
Subaru 1998-2002 FORESTER 2002 IMPREZA
1971 - 1973 1200
1972 - 1979 620 PICKUP
1966 - 1970 1600
1974 - 1977 710
1968 - 1970 2000
1980 720 PICKUP
1977 - 1986 200SX
1983 - 1986 720 PICKUP
1979 - 1982 210
1977 - 1981 810
1970 - 1973 240Z
1974 - 1978 B210
1975 - 1977 280Z
1986 - 1989 D21 PICKUP
1979 280ZX
1976 - 1978 F10
1990 - 1996 300ZX
1982 - 1984 MAXIMA
1979 - 1982 310
1987 - 1989 PATHFINDER
1967 411 ,  1983 PULSAR
1968 - 1973 510
1983 - 1990 PULSAR NX
1978 - 1981 510
1982 - 1990 SENTRA
1965 - 1968 520 PICKUP
1982 - 1986 STANZA
1969 - 1972 521 PICKUP
1988 VAN
1973 - 1976 610
