When the engine is fully warmed, the choke must be fully off for correct operation. When the engine is cold, the choke should be partly for fully closed. When the outside temperature is cold and engine is cold it must be fully closed.
Choke open: Choke knob pushed in Choke closed: Choke knob pulled out
Automatic Choke
To adjust the automatic choke, slightly loosen the three screws holding the round part. Rotate it counterclockwise for more choke, clockwise for less. The nominal (initial) setting is on the middle mark:
OK, here's the secret:
- Set it (engine fully cold) just tight enough to just close the choke completely when tthe throttle is opened. Since it depends on outside temperature, adjust summer and winter if necessary.
- Then warm the engine up. Blip the throttle occasionally to let the choke open as the spring warms. If, when the engine is fully warm, the choke hasn't completely opened, there is a problem. Check the spring on the choke. If it don't have enough 'spring', by a new electric one. It's just wired to the IGN (full +12V, before ballast resistor).
- Note the single mark on the cover. Initally it is lined up in the center, then final adjusted per Step 1. In the winter set it a mark or two tighter (following step 1). Loosen the screws to turn this.
Fast Idle Adjustment
This should only have an effect when the engine is cold, as it is related to the choke. The engine should run fast when started, then as it warms up and the choke is gradually released (blip the throttle to 'set' the cam), it should run slower until as the engine warms more, it comes off the cam and has no effect on warm engine.
Adjust for about 1200-2000 rpm (cold) or to your preference. It should be fast enough to run good, but not too fast. While Nissan has a specification, really it depends a lot on how cold it is where you live. If everything else is adjusted correctly (timing, no vacuum leaks, etc), you should be able to take off immediately and drive the car without "warming it up". If it dies, use a higher fast idle.
Manual Choke
Manual choke adjustment procedure: There is no adjustment.
- To start when cold, pull the knob out.
- After starting, push the knob in a bit
- While warming up, constantly push the knob in or out until it runs right
- When fully warm, the knob should be all the way to the dash
The only thing to check regarding choke, mechanically speaking is:
remove air cleaner and inspect:
- Knob all the way out: ensure butterfly valve is fully closed
- Knob all the way in: ensure butterfly valve is fully open
