Datsun 1200s came with different types of seats, depending on the market. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Coupe Seats - sporty trim, but light with very little padding
Sedan Seats - flatter, with a bit more padding
Danish two-tone seat option (sedan)
Sunny Truck
Many B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replaced with an adjustable seat rail.
-7803 Early Datsun 1200 utes
- sedan seat bottom
- Truck unfinished back
- fixed (non-reclining)
- thin headrest
- 87700-G1001 Head Restaint Assy OPTION ALL(assist)
7803-8910 - Brown
High back seat (no external headrest)
[1]
Late Seats
later seats have passenger side lower mount -- to clear the catalyst bulge in the floor.
1976-1978 B-210 pictured here (1989-up Sunny Truck is similar)
Stock Seats
1972 USA Owners manual (see pages 4-5 for Seat information):
The rear [Coupe] seat area may be quickly and easily converted into baggage space when needed.
USA models:
- 1973 models had blue or beige seats. Black was available (again) on from 0173
- 1971-1972 models:
- Coupe: Black, Beige or (optional) Yellow
- Sedan: Black, Yellow, Gray
- Reclining seats standard on coupe
- Sedan had folding non-reclining seats with (optional) reclining seats
- Sedan had some sort of optional front seats
Standard, Deluxe and Reclining Seats
Aussie-Market
1200 Coupe seats (custom fabric) in Datsun 1000
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to Japan seats with a slim-profile headrest.
Parts
- 86982-A0600 Eyelet 'A' Seat Back $1.12
- 86983-A0600 Eyelet 'B' Seat Back $0.85
- 87550-H1603 Slide-seat LH $44.33
- 87500-H1603 Slide-seat RH
- 87400-M3000 Hinge-recline RH $179.58
- 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
- 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
[http://datsun1200.com/uploads/newbb/thumbs/13022_4e1d16242df7e.jpg]
- 74961-H1100 TRIM-seat riser (R.H.) DX, GL
- 74962-H1100 TRIM-seat riser (L.H.) DX, GL
TRIM-SEAT RISER, RH
- 74961-H1100 7510-7803 BLACK
- 74961-G1060 7804-8910 DARK BROWN
- 74967-95W00 8910- GRAY
TRIM-SEAT RISER, LH
- 74962-G1000 -7803 BLACK
- 74962-G1060 7804-8910 DARK BROWN
- 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
- 66919-H1001 -7803 BLACK
- 66919-H1001 is superseded by 01553-00291 $0.80 USD
- 66919-G1060 7804-8910 DARK BROWN
- 96815-B0700 8910-
TRIM CLIP is also used by the Kick Panel and coupe rear interior panels
Headrests
Head Rests 87700-H1001: Black Coupe, Sedan, Van 1970-1973 (op. Van STD) 87700-H1002 Head Restraint Ass'y-driver seat 三ツ? JAPAN [alternate] 87700-H1003 Head Restraint Ass'y-driver seat (Yellow) JAPAN Sedan DX, Coupe DX 87700-H7000: Blue 1973 USA Coupe, Sedan 0772- 87700-H7001: Beige 1973 USA Coupe, Sedan 0772- 86981-A0601 PLUG-seat back (for assist seat) 2 86982-A0600 EYELET-seat back "A" 4 86983-A0600 EYELET-seat back "B" 4
Rear Head Rest (Sedan) 88700-H1000 HEAD RESTRAINT ASS'Y-rear seat 2 (op. Sedan) 88700-H1003 HEAD RESTRAINT ASS'Y-rear seat (Yellow) 2 (op. Sedan DX) 08340-82520 SCREW fixing head restraint 4 08915-13810 WASHER-lock fixing head restraint 4
Alternative Seats
Recaro Seats
Recaro is the premium automobile seat company.
Upholstery
See main article : Upholstery
Custom Upholstery
Racing Seats
Seat Rails
Seat rails are two kinds:
- Full adjustable fore-aft sliding
- Non-sliding (truck passenger side)
Just unbolt the rails from your seats and bolt them to the new seat:
Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
- Side to side: 15-11/16 inch
- Front to back: 12-3/16 inch
Truck
フロント シート <トリム>
87500-G1000 SLIDE ASS'Y-driver seat ドライバ- シート スライド -1974 87501-G1000 SLIDE-RH SEAT, OUTSIDE スライド、RH シート アウトサイド 87502-G1000 SLIDE-RH SEAT, INSIDE スライド、RH シート インサイド 87556 87505-G1000 BRACKET ASSY-FRONT SEAT, LH ブラクット アッセンブリ、フロント シートLH RISER ASS'Y-seat シート ライザー [non-adjustable?]
08110-81862 BOLT fixing slide to floor (8) 08915-43810 WASHER fixing slide to floor (8) 08310-82014 SCREW fixing slide to seat (8) 08310-81812 -7510 08915-13810 WASHER fixing slide to seat (8)
Bride
- The famous Bride rails for Sunny Truck
- 200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
- Front to back (left side): 12-3/16 inch
- Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
- slanted tabs
- 15-1/2" at base, 16-1/4" at bottom edges
- front tab: 1-7/16" long
- rear tab: 1-3/8" long
- slanted tabs
Bride B122 Part Numbers
- LH: code N030VO type V*1 TTM-L No. 939063
- RH: code N029VO type V*1 TTM-L No. 939064
- V type: for Bride full bucket, 30 mm height
- S type: for Bride reclining seat
- VF type: for Bride full bucket, no slide (fixed position)
Adapting Seats
B210* seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
* early B210 seats fit B110 directly * late B210 seats have a non-flat bottom
If you don't have the B110 rails, you can adapt B210 or B310 slides:
Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Chassis Brackets - for flat seat runners
Account and pictures of how to adapta Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
See Rear Seat
Australia Legalities
