Pedals
Revision as of 23:42, 29 December 2012; view current revision
Category: Body
20631.jpg th_willieoec-img600x450-1327301597khao5r38841.jpg th_willieoec-img600x450-1327301597qhkfya38841.jpg th_willieoec-img600x450-1327301597tfg2sp38841.jpg
Adjustment
Brake Pedal
  1. Loosen the stopper nut
  2. Measure height of pedal. It should be 143.5 mm. Insert shims on outside of firewall until height is 143.5 mm
  3. Tighten stopper until height is 139.5 to 143.5 mm. Tighten stopper nut.
  4. Double-check free play (5-15 mm)
  5. Double-check total travel of pedal (120mm)
Clutch Pedal
See:
Accelerator Pedal
See Accelerator Pedal
The pedal boxes are the same manual & auto. But brake pedal width differs.
See main articles:
Brake Pedal Part Numbers
Clutch Pedal Part Numbers
Pedal bushing: B10, B110, B210 & B310 USA & JDM:
  • 46525-18000 BUSHING-pedal fulcrum (2)
    • replaced by 46525-N8200 0880-up $1.64 USD
  • 46512-H0101 RUBBER-BRAKE PEDAL STOPPER $3.00 USD
  • 46531-18001 COVER-PEDAL PAD for BRAKE MANUAL $2.52
  • 46531-20301 COVER-PEDAL PAD for BRAKE AUTOMATIC NLA
  • 46525-18000 BUSH-PEDAL FULCRUM for CLUTCH $1.64 USD
  • 46531-M3000 COVER-PEDAL PAD for CLUTCH $2.52 USD
    • formerly 46531-18001
See Dash Part Numbers
B210 manual pedal boxes have an extension welded on the left side. So they are not interchangeable with auto pedal boxes. Brake booster makes a difference too.
B210 JDM Pedal Box
45670-H5000 Manual A12
45670-H5800 Manual for use with booster
* A12 GX,MTM OPT GL,MTM from '75-4
45670-H5020 Automatic A12 1973-1975
45670-H5820 Automatic for use with booster
* GX,ATM OPT GL,ATM from '75-4
MTM: GX マスターバック, GL ラインオプョン
