Hitachi Twin Carb Part Numbers
Revision as of 21:50, 16 January 2013; view current revision
Categories: Fuel System | Hitachi Twin Carb
[hide]
38 mm
38 mm (1-1/2")
HJB
38 mm (1-1/2"):
  • HJB38W-1: 1963-1964 SP310 1500 Roadster G engine
  • HJB38W-3: May 1965-1967 Roadster SPL311-1600 (R16 engine), CSP311 Silvia
HJE
38 mm
  • HJE38W-1: 1964 DP410MTK (410 Bluebird)
    16010-10615
    • Used two right-hand carbs, with right-angle forward-facing fuel inlets
    • Used twin-snorkel air cleaner, with dual interior right-angle air horns.
  • HJE38W-2: 1966 411 SS Bluebird (DP411MTK & DP411RTK)
    16010-16710
  • HJE38W-3: 411 Bluebird 1600 (DR411)
    16010-15800, 16010-18810
    • Used two right-hand carbs, with right-angle engine-facing fuel inlets
    • Different mounting angle
    • Same air cleaner as 410
    • Used bar linkage, (similar to a twin Mikuni setup)
  • HJE38W: B110GTK, KB110GTK Datsun Sunny 1200 GX
    16010-H2330 front
    16010-H2331 rear
  • A12 GX from '70-Jul
    16010-H2332 front
    16010-H2333 rear
  • A12 GX from '71-11
    16010-H2334 front
    16010-H2335 rear
  • From '73-1
    16010-H2336 front
    16010-H2337 rear
    • Fuel bowl outlets: Banjo fitting
    • Fuel bowl inlets: Engine-facing nipples
  • HJE38W - look like GX.
    Banjo type overflows on rear of fuel bowls
    Inlets point to valve cover
    16010-H2332 PE10 A12T front
    16010-H2333 PE10 A12T rear
  • HJE38W-5C PE10 A12T (from '71-11)
    16010-M0830 front
    16010-M0850 rear
  • HJE38W-5E PE10 A12T (from '73-1)
    16010-M0831 front
    16010-M0851 rear
  • HJE38W-8A PE10 A12T (from '73-3)
    overflows straight up
    Inlets on outside of fuel bowls
    16010-M0832 PE10 A12T front [flat tops]
    16010-M0852 PE10 A12T rear [flat tops]
  • HJE38W-8 B210 A12T
    16010-H5731 front [flat top]
    16010-H5751 rear [flat top]
    • OPTION hot air cleaner
Unknown Type 38mm
  • B210 A14T [Flat Tops, new type]
    • Triangular shaped throttle plates
HJL/HTL
38mm
  • HJL38W-1A: 1969 P510 SSS [P510TK], CSS [KP510TK]
    16010-22002, 16010-22004
    • Fuel inlet, engine facing banjo
  • HJL38W-2A: P510 SSS, CSS OPTION
    16010-22005
  • 1971 510 SSS P510TK (1600), KP510TK, H510TK (1800), H510ATK, KH510ATK
    • same fuel inlets as B110 GX
  • HJL38W-5 L14T circa 1972 PB110
    • Fuel bowl outlets: upward pointing nipples
    • Fuel bowl inlets: Engine-facing nipples angled up
    • Fat air cleaner from 7110
  • 1972 510 SSS
    • Fat air cleaner
  • HTL28W-6: 1972-1973 610 twin carb ass'y
    16010-U0800
  • HJL38W-6A: 1973 610 L16T, L18T (from '72-7)
    16010-U0831 front [flat top]
    16010-U0851 rear [flat top]
  • HTL38W-7: 1973 610 L16T, L18T (from '73-3)
    16010-K1430 front [flat top]
    16010-K1450 rear [flat top]
  • 1975 610
    16010-K1431 front [flat top]
  • HJL38W-8 PB210 L14T [Flat Tops]
  • HJL38W-7 710 L16T [flat tops]
    16010-K1430 front
    16010-K1450 rear
  • HJL38W-7 710 (from '73-6)
    16010-K1431 front
    16010-K1451 rear
  • N510 1971 catalog
    • 16010-N0410 L16T, 1800 SSS
    • 16010-U0800 L16T
    • 16010-U0831 L16T
    • 16010-U0851 L16T
    • 16010-A8700 1971 L18T, late 1600 SSS
Bluebird 910 SSS (Europe, 0180-1283)
16010-K1436 910 Front Carburetor
16010-K1546 910 Rear Carburetor
46 mm
46 mm (~1-13/16)
  • HJL46W: ?
  • HJG46W: Roadster U20 (SRL311-2000)
  • HJG46W-3A: S30 (240Z) Manual Trans -0871
    • HJG46W-R3A rear carb
    • HJG46W-F3A front carb
  • HJG46W-4: S30 Automatic 0870-0871
  • 1972 changed to water-heated carbs
  • HJG46W-8: S30 1972 manual trans
    • HJG46W-R8B rear carb
    • HJG46W-F8B front carb
  • HJG46W-9: S30 1972 auto trans
    • HJG46W-R9A: rear carb
    • HJG46W-F9A: front carb
  • HBM46W-1 1973-1974 (240Z & 260Z Flat Tops)
http://www.zparts.com/zptech/articles/mal_land/ml_sucarb2/SUcarb_111601b.htm
