Battery relocation means moving the battery from it's normal place. Typically this is done to make room for engine swaps, or to move it to the back to change the weight distribution.
Cables
- Use large-gauge battery cables
- Use a negative cable (do not rely on chassis ground)
Connect the negative cable directly to the engine block (as in standard Battery cable mounting).
Consider a racing-style battery disconnect.
Boot Mounting
Truck
In a ute there is plenty of weight under the tray to mount a battery.
