Datsun 1200 axle shafts come in two sizes: H145 for all cars, and H165 units for all 1200 Trucks. Both are 23-spline axles, although the truck axles are a larger diameter and so they do not interchange.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Wheel Bearing Packing
Axle Seal
Suppliers - USA
- Nissan
- RockAuto differential parts
- http://www.partsamerica.com
Axle
- 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
- 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
- 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
- Also B210 H165B with L16 engine
Axle Seal
Datsun 1200 uses the same rear axle/wheel hub seal as Datsun 510. One is required for each side of the car. The same seal is used by H145 (1200 car) and H165 (1200 truck) rear axle assemblies.
Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT * formerly 43252-18000 * alternate manufacturer: 43252-H1010 Nissan catalog SEAL-GREASE, REAR HUB 43232 * 1200 sedan/coupe/wagon/truck * Datsun B10 Datsun 1000 * Datsun 210 1978-1982 * Datsun 510 1968-1973 * Datsun 610 1974-1976 * Datsun 710 1974-1977 * Datsun 810 1977-1881 * Datsun B210 1974-1978 * Datsun A10 1978-1981 (Stanza/510/Violet) * Nissan/Datsun 810/910 wagon (810/Maxima/Bluebird) * Datsun S10 200SX 1977-1979 * Datsun S110 200SX 1980-1983 * Nissan S12 200SX 1984 with CA20E engine * S12 CA18S * C120/C22/C23 Vanette NOK * K30/K30S Crew * 910 Bluebird SSS * C31/C32 Laurel * F30 Leopard * R30/R31 Skyline SEAL-OIL, SIDE SHAFT (4WD front final drive) 38542P * Nissan D21,D21U,D22 Hardbody/Datsun pickups 1986-2000 * Nissan R50 Pathfinder/Terrano/テラン rear outer * Nissan JR50 * W10 Avenir * WD21 テラン * Nissan WD21,WD22 "Pathfinder" * Nissan E50.4WD/AE50.4WD ElGrand * F22.4WD/F23.4WD Atla/Cabstar
Aftermarket SKF OS550232 Timkin 1181 BECK/ARNLEY 0521583 (052-1583) Payen NJ036 Masashi N2125
Timkin 1181 Specifications * For 41.00 mm Shaft * Housing bore: 56.00 * Seal O.D.: 56.25 * Seal width: 7.00 * Lip material: Nitrile (NBR)
Timkin 1181 cross-reference * CAUTION: parts listed below may meet lesser specs * Cam seal, Crank seal, Wheel Hub seal (front), axle seal (rear) 4WD IRS front final drive side shaft seal Timkin 1181 41x56x7 Beck/Arnley 052-3605 41x56x8 Beck/Arnley W72173 Beck/Arnley W72231 Nation 1181 GM 12305324/15527580 ITM 1501004 Bap-Geon 1530501/1530505 SKF 16496 SKF 550232 Vera 6501018 Vera 6601000 Victor 66545 Victor 66984 Intlps 775532 Acura 91212P5G-004 Acura 91212PH7-013 Acura 91212PY3-003 Honda 91212PH7-003 Honda 91212PH7-013 Honda 91212PR7-A01 Honda 91212PY2-003 Honda 91212PY3-003 L&S/TROSTL A45556S Guran/Midas GS1386 Victor JV1054 IAPCO L0020012 Nissan 40232-M0200 Lazorlite L816671 Lazorlite L817376 Payen NJ036 41x56x7 NBR Payen NJ120 41x56x8 Payen NK023 41x56x8 ACM Repco P6374 Repco PR6374 Repco 2116374
Axle Bearing
H145
A new collar is required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
Nissan 43255-H1000 COLLAR-REAR AXLE BEARING Beck Arnley 0530014
Sedan, Coupe =
Nissan 43215-18000 BEARING-REAR AXLE SEDAN, COUPE * SKF GRW115R * KOYO 83294C4 * NSK B32-3CC5 * NTN 6206BLUX/32C4 $28 USD![]()
Interchange: * 1967-1970 Datsun B10 (180 is B10 part number) * 1970-1973 Datsun B110
Specs: * O.D.: 62.000 (mm) * Bore: 30.000 (mm) ** ?? 32 mm * Width: 16.000 (mm)
Wagon =
Nissan 43215-22500 BEARING-REAR AXLE VAN * same as used in B210 and 1200 Ute, except non-sealed
H150/H165
43215-H5000 BEARING-REAR AXLE, OUTER B120, B210 H150 * replaced 43215-22500
* SKF GRW114R * Beck/Arnley 0513202 * National RW114R * Timken RW114R
Specs * Bore 32mm (1.2598") * Outer Diameter 72mm (2.8346") * Width 19mm (0.748") * Sealed RETAINER 43255-H1000 COLLAR-BEARING,REAR AXLE SHAFT * National R114 $2.49 USD * Beck/Arnley 0530014 RockAuto.com
