The Datsun 1200 used a leaf-spring live axle with an H145 differential. This is a Hitachi design with 145mm ring gear. It is a lightweight unit suitable to handle the torque from an A12 engine. Light weight is good. Heavy parts take more horsepower to accelerate.
Also see Rear Axle Swaps.
Maintainence
The stock Datsun 1200 differential is a reliable, long lasting part behind an A12 or A13 engine.
- As long as it doesn't run dry on gear lube it will usually last forever. So check it every few months for signs of leaking.
- The only common maintainence is to pack the rear wheel bearings every two years or so. This will also keep the bearings quiet and reduce gear lube leakage into the brake area.
Differential Lubricant
- the traditional "90 weight" gear oil
- the newer 75W140 multi-weight gear oil
For maximum fuel economy, use a modern multi-weight gear oil.
The original specifications (which are still OK to use) are:
- Specification: API GL-4MIL-L-2105
- CHEVRON Multiservice Gear Lub. 75,80,90,140
- ESSO Gear Oil GP80,90,140
- MOBIL Mobilube EP or GX80-90, 90, 140
- SHELL Spirax 75EP,80EP, 90EP, 140EP
- SUNOCO Multipurpose GearLub. GL-480,90,140
- TEXACO Universal Gear Lub.EP80,90,140
reference: Owners manual
Online Owner's Manual
Suppliers - USA
Rear Axle Seal
- Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
Rear Axle Bearing
- Nissan 43215-18000 BEARING-REAR AXLE
- Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
NOTE: 180 is B10 part number, so B10 and B110 should interchange
Differential Axle Bearing
1.1811 in. I.D; 0.6299 in. width; Fits H145 & H150.
Taper Bearing Assembly: Cone Length=0.6299" Bore=1.1811" Outer Diameter=2.4409" Width=0.6791" Cup Length=0.5512" Cone Radius=0.06" Cup Radius=0.06"}
Application: Alfa, Mitsubishi, Ford, Mazda, Nissan, Plymouth, Porsche, Subaru
PartsAmerica
- SKF BR30206 - $16.99
- BCA 30206 - $29.99
- Motor City S30206 - $9.88
- TIMKEN Part # 30206M - $14.96
- BCA/NATIONAL Part # 30206 - $16.74
Pinion Seal
B110, through 1974 model year B210. Probably fits B10 as well.
Partsamerica.com pinion seal
- SKF Oil Seal #550219 $22.99
Pinion Bearing
Fits many cars, GM, Nissan, Isuzu, Mazda, Opel, etc
Taper Bearing Assembly: Cone Length=0.7874" Bore=1.1811" Outer Diameter=2.4409" Width=0.8366" Cup Length=0.6693" Cone Radius=0.06" Cup Radius=0.06"}
Rockauto
- BCA/NATIONAL Part # 32206 - $19.84
- SKF BR32206 - $18.99
Unformatted Nissan Parts List
Nissan North America
- 43010-H1003 COMP-CASE REAR AXLE 1 SEDAN 1272-0573 32 43010-H1002
- 43010-H1004 COMP-CASE REAR AXLE 1 SEDAN 0673- 5 43010-H1003
- 43010-H1802 COMP-CASE REAR AXLE 1 COUPE -1172 2
- 43010-H1803 COMP-CASE REAR AXLE 1 COUPE 1272-0573 32 43010-H1802
- 43010-H1404 COMP-CASE REAR AXLE 1 COUPE 0673- 5 43010-H1803
- 43010-H1002 COMP-CASE REAR AXLE 1 SEDAN -1172 2
- 43067-H0100 STUD-GEAR CARRIER FIX 8 -
- 43059-A1600 PLUG-TAPER SQUARE SOCKET 1 -
- 32103-14600 ASSY-PLUG DRAIN 1 -
- 38322-55100 ASSY-BREATHER 1 -
- 38162-G0300 ASSY-SHAFT REAR AXLE 2 -
- 40222-18000 BOLT-HUB ROAD WHEEL 8 -
- 43065-10600 CLIP-BRAKE TUBE 2 -
- 43066-22500 SEAT-CONNECTOR BRAKE HOSE 1 -
- 43070-04101 SPACER-REAR AXLE BEARING 2 -1172 2
- 43070-H5000 SPACER-REAR AXLE BEARING 2 1272- 2 43070-04101
- 43215-H5000 BEARING-REAR AXLE 2 SEDAN COUPE 0673-1172 25 43215-18000
- 43215-18000 BEARING-REAR AXLE 2 SEDAN COUPE -
- 43255-18000 COLLAR-REAR AXLE BEARING 2 -
- 43255-H1000 COLLAR-REAR AXLE BEARING 2 1271- 2 43255-18000
- 43036-10601 SHIM-REAR AXLE CASE END 0 SEDAN COUPE -
- 43036-H5000 SHIM-REAR AXLE CASE END 0 SEDAN COUPE 0673-1172 25 43036-10601
- 43239-04100 PACKING-GREASE CATCHER 2 -1172 2
- 43239-H5000 PACKING-GREASE CATCHER 2 1272- 2 43239-04100
- 43237-18000 CATCHER-GREASE RH 1 -1172 2
- 43236-18000 CATCHER-GREASE LH 1 -1172 2
- 43236-H5000 CATCHER-GREASE 2 1272- 2 43236-18000
- 43252-18000 SEAL-OIL REAR AXLE SHAFT 2 -
- 43252-H1000 SEAL-OIL REAR AXLE SHAFT 2 0372- 2 43252-18000
- 08915-23810 WASHER-SPRING LOCK 8 -
- 43063-18001 BOLT-FIX REAR BRAKE DISC 8 -
- 08912-43810 NUT-HEX SELF LOCK 8 -
- 43206-18000 DRUM-BRAKE 2 -
- 40300-H1001 ASSY-ROAD WHEEL 4JX12 3 DELUXE -
- 40312-H1922 TIRE 6.00-12-4PR FMVSS 3 -
- 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS 3 OP -
- 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL FMVSS 3 OP -
- 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WITHE FMVSS 3 OP -
- 40315-H1100 COVER-ROAD WHEEL 2 DELUXE (OP STD) -
- 40315-H1800 COVER-ROAD WHEEL 2 OP COUPE -
- 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) 2 COUPE 0872- 5 40315-H1800
- 40225-27700 NUT-ROAD WHEEL 1 16 -
- 40325-H1000 WEIGHT 50G WHEEL BALANCE 0 - 2 40326-18000
- 40330-18000 WEIGHT 100G WHEEL BALANCE (NOT ADOPTED 0 -
- 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED 0 -
- 40328-18000 WEIGHT 80G WHEEL BALANCE (NOT ADOPTED 0 -
- 40327-H1000 WEIGHT 70G WHEEL BALANCE 0 - 2 40327-18000
- 40322-18000 WEIGHT 20G WHEEL BALANCE 0 -
- 40327-18000 WEIGHT 70G WHEEL BALANCE 0 -
- 40326-H1000 WEIGHT 60G WHEEL BALANCE 0 - 2 40326-18000
- 40326-18000 WEIGHT 60G WHEEL BALANCE 0 -
- 40325-18000 WEIGHT 50G WHEEL BALANCE 0 -
- 40324-H1000 WEIGHT 40G WHEEL BALANCE 0 - 2 40324-18000
- 40324-18000 WEIGHT 40G WHEEL BALANCE 0 -
- 40323-H1000 WEIGHT 30G WHEEL BALANCE 0 - 2 40323-18000
- 40322-H1000 WEIGHT 20G WHEEL BALANCE 0 - 2 40322-18000
- 40321-H1000 WEIGHT 10G WHEEL BALANCE 0 - 2 40321-18000
- 40321-18000 WEIGHT 10G WHEEL BALANCE 0 -
- 40323-18000 WEIGHT 30G WHEEL BALANCE 0 -
- 40360-H1000 CHAIN-TIRE 4 OP COUPE -
