Datsun 1200 uses a throttle cable with twisted-braid steel core. A cable is better than linkage for smooth throttle action. RHD and LHD differ by length.
Contents[hide] |
Ends
Both RHD and LHD use the same clip on the interior to fix the cable to the Accelerator Pedal.
- 18036-18000 SPRING-CLAMP ACCELERATOR WIRE
- fixes cable to accelerator pedal
Ferrule end (that clamps to the carburetor)
- 8mm diameter x 21mm long ALL
Cable
Since the carburetor is always on the same side, the accelerator cable length is different for RHD and LHD models.
When replacing, adjust cable for 1mm play at the carburetor cable clamp.
Left-Hand Drive
- B110: A8200-G1300 ASSY-WIRE ACCELERATOR [40 mm length] $7.30 USD
- Superceded old part number 18200-H1600
- B210: 18200-H7200 ASSY-WIRE ACCELERATOR A14 FED(GFU) From 12/76 $20.81 USD
- B210: 18200-H6102 ASSY-WIRE ACCELERATOR $19.08 USD
- Superceded 18200-H6100
Length measured firewall to end of cable ferrule
- B110: 40 mm long ball-end
- B210: 43.5 mm long ball-end
- B310: 40 mm long eyelet-end
Right-Hand Drive
- 18200-H1000 WIRE ASS'Y-accelerator B110 [85 cm length, tube 72cm]
- 18211-18001 RING-wire clamp
- 18200-G1601 ASSY-WIRE ACCELERATOR B120 -8910
- 18201-95W00 ASSY-WIRE ACCELERATOR B120 8910-
- 24222-89901 CLIP-WIRE, ACCELERATOR 9810-
Other Part Numbers
- 18200-18000 WIRE ASS'Y-accelerator B10 superceded
- 18200-18001 WIRE ASS'Y-accelerator B10 replaces 18200-18000
- 18200-27700 WIRE ASS'Y-accelerator B10 replaces 18200-18001
- 18200-H5000 WIRE ASS'Y-ACCELERATOR B210 early
- 18200-H5005 WIRE ASS'Y-ACCELERATOR B210 early GL op. and late B210
- 18200-H5205 WIRE ASS'Y-ACCELERATOR B210 GX A12T
- 18200-H7510 WIRE ASS'Y-ACCELERATOR B210 A14T
- 18200-H7900 WIRE ASS'Y-ACCELERATOR B210 L16
- 18200-H8501 WIRE ASS'Y-ACCELERATOR B310 Rockauto $11
- 18200-H8502 WIRE ASS'Y-ACCELERATOR B310 NLA
- 18200-H9205 WIRE ASS'Y-ACCELERATOR B310 A14E, A15E
GX Cable Routing
GX uses same cable as others RHD Datsun 1200s.
Weber DGV Cable
See DGV#Throttle_linkage
Sidedraft Cable
B110 Catalog A8200-G1300 ASSY-WIRE ACCELERATOR 18200-H1600 ASSY-WIRE ACCELERATOR
