Weight
Revision as of 03:23, 6 September 2013; view current revision
Category: General Information
Datsun 1200 weighs about 1640 pounds (745 kg) depending on year, options, and how much fuel is in the tank.
[hide]
Documentation
Weight Distribution (Front/Rear)....54/46
Consumer Reports Sep 1971
Weight .................. 14cwt
MOTORMAN magazine
Curb Weight: 1,609 lbs (731 kg)
Mechanix Illustrated 1973 article
CURB WEIGHT ... 1613 pounds (733 kg)
Consumer Reports 1971 September Road Test
Datsun 1200 Weight
4-dr manual 1532 lbs (696 kg)
4-dr auto 1609 lbs (731 kg)
2-dr coupe 1520 lbs (691 kg)
5-dr wagon 1609 lbs (731 kg)
Source: Aussie brochure:
Japan published weights (source: Datsun factory parts catalog C-231)
B110S   690 kg STD trim
B110SR  665    STD 2-dr sedan
B110    700
B110R   685    DX 2-dr
B110A   735    AUTO
B110RA  720
B110G   705    GL
B110GR  690
B110GA  740
B110GRA 725
VB110   735    Van
VB110S  715
KB110   695    Coupe
KB110G  700
KB110A  730
KB110GA 735
B110GTK 710    GX Coupe
B110GK  705    GX Sedan
Curb weight 2-dr coupe: 1650 lbs (750 kg)
Curb Weight 2-dr sedan: 1630 lbs (741 kg)
Add 75 lbs for automatic transmission (34 kg)
Source: Nissan USA statistics
Measured
It all depends on how much fuel is in the tank at time of weighing, and if using stock components which are generally lighter than non-stock wheels, tires and suspension pieces. Plus options like carpet, transmission type, etc.
Ute
[http:/datsun1200.com/modules/newbb/viewtopic.php?post_id=410623#forumpost410623 Ange had his ute weighed] pre-conversion. It was 730kg.
Ute: 730kg (one example measured)
Coupe
Kelmo weighed his stock 1973 USA coupe, with aftermarket wheels.
Front left: 463
Front right: 464
Rear left: 385
Rear right: 375
Total: 1687 pounds
Sedan
ddgonzal measured his stock 1972 sedan with 1/4 tank fuel: 1640 pounds
