Hitachi Twin Carb
Revision as of 04:30, 6 July 2007; view current revision
Category: Fuel System
Some Datsuns were fitted with sidedraft carburetors right from the factory. Usually fitted with twin Hitachi variable venturi carburetors which are very similar to S.U. (Skinners Union) carburettors from Britain. The Datsun 1200 GX models were fitted with twin Hitachi 38mm carburetors. Many Datsun fans refer to the Hitachis as "SUs", so keep that in mind when you read information. It may be about the Hitachi sidedrafts, or it may not.
Reportedly, Hitachi licensed the SU design, but I have yet to see a reference for that (Nissan manual, etc).
Datsun twin-carb setups used two basic Hitachi sizes:
  • 38 mm (1-1/2 inch bore) on most cars
  • 46 mm (1-7/8 inch bore) on Z-cars. These are too big for Nissan A engines (even if you use one) and reportedly the late model flat top 46s are a bad design.
For true bolt on experience, you will need a complete setup:
  • Intake manifold
  • Exhaust manifold (twin down-pipe cast headers). The clearance differently than regular manifolds
  • Two carbs
  • Fuel lines
  • Accelerator cable & linkage
  • Choke cables
  • Air cleaners
In general on a given manifold you can use SU, Zenith-Stromberg (ZS) or Hitachi sidedrafts, but note that the linkage, hose locations and air cleaner attachment will vary.
A12 GX Engine
B110 GX (Grand Luxe Twin-carb) models were fitted with the A12 GX Engine. This featured a matched pair of left- and right- hand Hitachi HJE38W carbs. These mount at an angle and feed into the monster GX ports of the cylinder head. On a RHD car there is clearance aplenty, but on a LHD car fitting an air cleaner it a bit tricky. But this is more easily fitted to LHD than a twin-Weber setup.
These are the true "dome-top" Hitachis, already setup for performance. They can use standard SU needles so tuning it quite easy.
A12T Engine
Some Cherry models, and 1974-1975 B210s had the A12T twin-carb engine. While very similar to the A12 GX Engine, the A12T engine used different, flattop Hitachis and a slightly different intake manifold.
A14T Engine
Starting around 1976, the A12T was phased out and the A14T started. Unlike the original A12GX engine with its monster intake ports, the A14T used standard A14 oval ports (28 x 34 mm).
These are flat-top carbs, probably the same as L18SSS engines, heavily modified from the original SU-style design, apparently to add much emission controls. These are decent carburetors that only need a few simple modifications. For details see: The Hitach-SU Tech Pages - Flattops.
Features:
  • EGR port
  • Flat-top triangular-bell Hitachis
  • Vacuum ports on each end, top of manifold
  • No PCV valve fitting
Carb side:
  • 4-bolt pattern on 3.5 in. circle
  • 1.5 inch bore
  • Carb spacing approx 7-1/8 inch
  • Water ports at bottom
Parts Donors
  • A12 GX import engines
  • Datsun Competition setups
  • Datsun Roadsters: Reportedly, all Roadsters were fitted with Hitachis except the 2000 Roadster (2-liter engine) which came with Solex carbs.
  • Datsun 411 SSS (circa 1966)
  • Datsun 510 SSS
  • Datsun 610/710 SSS
Tuning
Go here for lots of information: The Hitachi-SU Tech Pages.
Troubleshooting
Go here for lots of information: The Hitachi-SU Tech Pages - Troubleshooting.
References
  1. Nissan Motorsports catalog (#99996-CAT98 and other years)
  2. Nissan Schematic catalog (#99996-M8015)
Links
