Rear Brake Part Numbers
Revision as of 06:38, 15 December 2014; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Rear Brake
[hide]
Early 1200
COMPLETE ASSEMBLIES
 Use with front disc brakes (GL, GX)
  44000-H0500 ASS'Y-BRAKE, rear (R.H.)
  44010-H0500 ASS'Y-BRAKE, rear (L.H.)
 Use with front drum brakes (STD, DX or Van)
  44000-27700 ASS'Y-BRAKE, rear (R.H.)
  44010-27700 ASS'Y-BRAKE, rear (L.H.)
 INDIVIDUAL PARTS
 1 44020-27700 ASS'Y-DISC, rear brake (R.H.)
   44030-27700 ASS'Y-DISC, rear brake (L.H.)
 2 44060-18000 ASS'Y-SHOE, rear brake, fore (2)
   44060-H0100 ASS'Y-SHOE, rear brake, fore (op.) (2)
 3 44070-18000 ASS'Y-SHOE, rear brake, after (2)
   44070-H0100 ASS'Y-SHOE, rear brake, after (op.) (2)
 4  41066-18000 LINING-brake (4)
    41066-H0100 LINING-brake (4) (op.)
 5 44081-18000 PIN-anti shoe rattler (4)
 6 44082-32200 SEAT-sprint (4)
 7 44083-32200 SPRING-anti shoe rattler (4)
 8 44084-32201 RETAINER-shoe rattler (4)
 9 44090-18000 SPRING-return brake shoe, cylinder (2)
10 44091-18000 SPRING-return brake shoe, adjuster (4)
cylinder assemblies
11 44100-18000 ASS'Y-CYLINDER, rear wheel (13/16") GL,GX (2)
   44100-18000 ASS'Y-CYLINDER, rear wheel (11/16") STD,DX or Van (2)
   12 44112-71200 CUP-piston (NABCO) (exc. GL,GX) (2)
      44124-71610 CUP-piston (TOKICO) (exc. GL,GX) (2)
      44112-18800 CUP-piston (NABCO) GL,GX (2)
      44112-16500 CUP-piston (TOKICO) GL,GX (2)
   13 44108-18000 PISTON-cylinder (NABCO) (exc. GL,GX) (2)
      44108-22010 PISTON-cylinder (TOKICO) (exc. GL,GX) (2)
      44108-18800 PISTON-cylinder (NABCO) GL,GX (2)
      44108-H0510 PISTON-cylinder (TOKICO) GL,GX (2)
   14 44113-31700 RING-snap (NABCO) (2)
      44113-31710 RING-snap (TOKICO) (2)
   15 44118-18000 ASS'Y-LEVER (NABCO) (2)
      44118-21910 ASS'Y-LEVER (TOKICO) (2)
   16 44124-31700 COVER-dust "A" (NABCO) (2)
      44124-31710 COVER-dust "A" (TOKICO) (2)
   17 44128-21900 SCREW-bleeder (NABCO) (2)
      44128-21010 SCREW-bleeder (TOKICO) (2)
   18 44129-30001 CAP-bleeder (NABCO) (2)
      41129-30001 CAP-bleeder (TOKICO) (2)
   19 44141-31700 SHIM-adjusting "A" (NABCO) (2)
      44141-31710 SHIM-adjusting "A" (TOKICO) (2)
   20 44142-31700 SHIM-adjusting "B" (NABCO) (2)
      44142-31710 SHIM-adjusting "B" (TOKICO) (2)
   21 44144-18000 COVER-dust "B" (NABCO) (2)
      44144-21910 COVER-dust "B" (TOKICO) (2)
   22 44149-31700 PLATE-"A" (NABCO) (2)
      44149-31710 PLATE-"A" (TOKICO) (2)
   23 44150-31700 PLATE-"B" (NABCO) (2)
adjuster assemblies
24 44200-18000 ASS'Y-ADJUSTOR, rear brake (2)
   25 44204-18000 WEDGE-adjustor (2)
   26 44205-18000 TAPPET-adjustor (2)
   27 89-15136-1 WASHER-lock, fixing adjustor (4)
   27 89-11106-1 NUT, fixing adjustor (4)
Repair Kits
Use with front disc brakes (GL,GX)
 NABCO
  44100-H0525 KIT-REPAIR, rear wheel cylinder "A" (NABCO)
  44100-H0526 KIT-REPAIR, rear wheel cylinder "B" (NABCO)
 TOKICO
  44100-H0527 KIT-REPAIR, rear wheel cylinder "A" (TOKICO)
  44100-H0528 KIT-REPAIR, rear wheel cylinder "B" (TOKICO)
Use with front drum brakes (STD,DX or Van)
 NABCO
  44100-18025 KIT-REPAIR, rear wheel cylinder "A" (NABCO)
  44100-18026 KIT-REPAIR, rear wheel cylinder "B" (NABCO)
 TOKICO
  44100-G0327 KIT-REPAIR, rear wheel cylinder "A" (TOKICO)
  44100-G0328 KIT-REPAIR, rear wheel cylinder "B" (TOKICO)
Late 1200
From 1989 October - Self-adjusting type
Fastening to axle housing flange
 08915-23810 WASHER (8)
 08912-43810 NUT (8)
 44000A BOLT
  44005-U1400 (8)
44000M BRAKE ASSY-DRUM,REAR RH
 44000-G1210
44010M BRAKE ASSY-DRUM,REAR LH
 44010-G1210
 44020 PLATE ASSY-BACK,REAR BRAKE RH
  44020-G1210
 44020G PLUG
  41098-70A10
 44030 PLATE ASSY-BACK,REAR BRAKE LH
  44030-G1210
 44060K SHOE SET-REAR BRAKE
  44060-G1225
 44081-M4901 PIN-ANTI SHOE RATTLE 4
 44083-W5200 SPRING-ANTI SHOE RATTLE 4
 44090-M4900 SPRING-RETURN,REAR BRAKE SHOE 2
 44091-M4900 SPRING-RETURN,REAR BRAKE SHOE (2)
 44100B
  01436-00052 BOLT (4)
 44100K CUP KIT-BRAKE WHEEL CYLINDER,REAR
  D4100-D5590 NABCO 3/4 (1)
  D4100-G2893 TOKICO 3/4 (1)
   44100P CYLINDER ASSY-REAR WHEEL
    44100-D5510 (2)
   44108 PISTON-CYLINDER (4)
    44108-D0101 NABCO
    44108-G2810 TOKICO
   44112 CUP-PISTON (4)
    44112-PO201 NABCO
    44112-P0211 TOKICO
   44124 COVER-DUST (4)
    44124-D5500 NABCO
    44124-17C10 TOKICO
   44125 SPRING (2)
    44125-M7010 TOKICO
    44125-U9200 NABCO
   44127 BOOT
    44095-M4910 (2)
   44128-U5200 SCREW-BLEEDER NABCO
   44129-A2410 CAP-BLEEDER SCREW TOKICO
44200N ADJUSTER ASSY-REAR BRAKE
 44200-W5211 RH
 44201-W5211 LH
44211-H8300 STOPPER-ADJUSTER LEVER
44212-H8300 FASTENER-ADJUSTER
Disc/Drum Setup
complete assembly
1 44000-H3300 ASSY-BRAKE REAR RH FOR FR DISC OP 0273- 2 44000-H0500
1 44000-H0500 ASSY-BRAKE REAR RH FOR FR DISC OP -0173 3
2 44010-H0500 ASSY-BRAKE REAR LH FOR FR DISC OP -0173 3
2 44010-H3300 ASSY-BRAKE REAR LH FOR FR DISC OP 0273- 2 44010-H0500
[individual parts]
3 44020-27700 ASSY-DISC REAR BRAKE RH OP
4 44030-27700 ASSY-DISC REAR BRAKE LH OP
5 44060-18000 ASSY-SHOE REAR BRAKE FORE (2) OP
6 44070-18000 ASSY-SHOE REAR BRAKE AFTER (2) OP
7  41066-18000 LINNING-BRAKE (4) OP
   * included with brake shoes
8 44081-18000 PIN-ANTI SHOE RATTLE (4) OP
9 44082-32200 SEAT-SPRING ANTI SHOE RATTLE (4) OP
10 44083-32200 SPRING ANTI SHOE RATTLE (4) OP
11 44084-32201 RETAINER-SHOE RATTLE (4) OP
12 44090-18000 SPRING-RETURN RR BRAKE SHOE CYLINDER (2) OP
13 44091-18000 SPRING-RETURN RR BRAKE SHOE ADJUST (4) OP
cylinder assemblies
14 44100-H3300 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP 0273- 2 44100-H0500
14 44100-H0500 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP -172 2
 15 44112-18800 CUP-PISTON(NABCO) (2) OP
 15 44112-H3300 CUP-PISTON (NABCO) (2) OP 2 44112-18800
 15 44112-16510 CUP-PISTON (TOKIKO) (2) OP 0273-
 16 44108-18800 PISTON-CYLINDER(NABCO) (2) OP
 16 44108-H0510 PISTON-CYLINDER (TOKIKO) (2) OP 0273-0173 3
 17 44113-31700 RING-SNAP(NABCO) (2) OP -173 3
 17 44113-U4000 RING-SNAP (NABCO) (2) OP 0273- 0 44113-31700
 17 44113-U4010 RING-SNAP (TOKIKO) (2) OP 0273-
 18 44118-18000 ASSY-LEVER(NABCO) (2) OP
 18 44118-21910 ASSY-LEVER (TOKIKO) (2) OP 0273-
 19 44124-U4000 COVER-DUST'A' (NABCO) (2) OP 0273-
 19 44124-U4010 COVER-DUST'A' (TOKIKO) (2) OP 0273-
 19 44124-31700 COVER-DUST'A'(NABCO) (2) OP -173 3
 20 41128-21900 SCREW-BLEEDER(NABCO) (2) OP -173 3
 20 41128-U0201 SCREW-BLEEDER (NABCO) (2) OP 0273- 0 41128-21900
 20 41128-U0512 SCREW-BLEEDER (TOKIKO) (2) OP 0273-
 21 41129-A2410 CAP-BLEEDER(NABCO) (2) OP -173 3
 21 41129-U0201 CAP-BLEEDER (NABCO) (2) OP 0273- 0 41129-A2410
 21 41129-30001 CAP-BLEEDER (TOKIKO) (2) OP 0273-
 21 41129-40F00 CAP-BLEEDER (TOKIKO) (2) OP 0273- 41129-30001
 22 44141-31700 PLATE-LOCK(NABCO) (2) OP -173 3
 22 44141-U4000 PLATE-LOCK (NABCO) (2) OP 0273- 0 44141-31700
 22 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) (2) OP 0273-
 23 44142-31700 PLATE BACK UP(NABCO) (2) OP -173 3
 23 44142-U4000 PLATE-BACK UP (NABCO) (2) OP 0273- 0 44142-31700
 23 44142-31710 SHIM-ADJUSTING'B' (TOKIKO) (2) OP 0273-
 24 44149-31700 SHIM ADJUSTING'A'(NABCO) (2) OP -173 3
 24 44149-H3300 SHIM-ADJUSTING'A' (NABCO) (2) OP 0273- 0 44149-31700
 24 44149-U4010 PLATE-LOCK (TOKIKO) (2) OP 0273-
 25 44150-31700 SHIM ADJUSTING'B'(NABCO) (2) OP
 26 44144-18000 COVER-DUST'B'(NABCO) (2) OP -173 3
 26 44144-U4000 COVER-DUST'B' (NABCO) (2) OP 0273- 0 44144-18000
 26 44144-U4010 COVER-DUST'B' (TOKIKO) (2) OP 0273-
[not shown in diagram]
27 44100-H0525 KIT-REPAIR WHEEL CYLINDER"A"(NABCO) (2) OP -173 3
27 44100-H3325 KIT-REPAIR WHEEL CYLINDER (NABCO) (2) OP 0273- 0 44100-H0525
27 44100-H3327 KIT-REPAIR WHEEL CYLINDER (TOKIKO) (2) OP 0273-
28 44100-H0526 KIT-REPAIR WHEEL CYLINDER"B"(NABCO) (2) OP -173 3
29 44200-18000 ASSY-ADJUSTER REAR BRAKE (2) OP
 30 44204-18000 WEDGE-ADJUSTER (2) OP
 31 44205-18000 TAPPET-ADJUSTER (4) OP
 32 08915-13610 WASHER-LOCK M6 (4) OP
 33 08911-10610 NUT-HEX M6X1.0-2 (4) OP
