Kick Panel
Revision as of 11:14, 20 December 2014; view current revision
Category: Interior
The Dash Side Trimming covers the side of the foot well, just forward of the front doors. These are popularly called "Kick Panels". The factory right and left speakers are mounted on the kick panel.
Kick Panel with optional speaker fitted:
The panels have a cut-out area for the speaker, which can easily be broken out and discarded in order to fit the speaker.
There is also a kidney-shaped plug in each panel, which gives access to the door hinge bolts.
Flare
For the Japan market, the flare was mounted to the kick panel:
Nissan 26890-89900
Effective date 1981 January
End date 1982 February 5
Custom
Carbon Fibre kick panels have been made.
Kick panels with designed speaker enclosure:
Covering with fabric:
  • 66900-H1001 TRIM-DASH SIDE RH
  • 66900-H1101 TRIM-DASH SIDE RH -7803 Black
  • 66901-H1601 TRIM-DASH SIDE LH -7803 Black
  • 66901-H1901 TRIM-DASH SIDE LH
  • 66901-G1060 FINISHER-DASH SIDE, RH 7804-8910 BROWN
  • 66901-95W00 FINISHER-DASH SIDE, RH 8910- GRAY
  • 66900-G1060 FINISHER-DASH SIDE, LH 7804-8910 BROWN
  • 66900-95W00 FINISHER-DASH SIDE, LH 8910- GRAY
    • 08540-41012 SCREW-TAPPING (4)
    • 08915-43420 WASHER-PLAIN (4)
  • 08410-61212 SCREW-MACHINE
  • 08410-61220 SCREW-MACHINE
  • 36528-22500 WASHER-PLAIN
  • 66904-H1001 PLUG-DASH SIDE RH -7803
  • 66905-H1001 PLUG-DASH SIDE LH -7803
  • 64891-W5000 PLUG 7804- D=30
  • 66919-H1001 CLIP-trimming -7804 (6) BLACK
  • 66919-G1060 CLIP-trimming 7804-8910 (6) BROWN
  • 66919-95W00 CLIP-trimming 8910- (6) GRAY
サイド トリム
