Also see:
Part Numbers Index Main article for usage, photos, cross-reference: Badges
Sedan
Early
Also see Grille Part Numbers#Early
RADIATOR GRILLE (SEDAN) 4 62312-H1026 SET-ORNAMENT, radiator grille fixing ornament 5 08915-43410 WASHER-plain 2 6 08915-13410 WASHER-lock 2 7 08911-10410 NUT 2 8 62330-H2026 SET-EMBLEM, radiator grille "GL" 9 62330-H2325 SET-EMBLEM, radiator grille "GX" fixing radiator grille emblem 10 62332-H2000 RETAINER-emblem 11 08915-43410 WASHER-plain 4 12 08915-13410 WASHER-lock 4 13 08911-10410 NUT 4
1972
Also see Grille Part Numbers#1972
7 62312-H3125 ORNAMENT KIT-radiator grille 8 08915-43410 WASHER-plain 2 9 08915-14340 WASHER-lock 2 10 08911-10410 NUT 2 11 62330-H3125 EMBLEM SET-radiator grille "DELUXE" 12 08915-43410 WASHER-plain 2 13 62330-H3325 EMBLEM SET-radiator grille "GL" 14 62330-H3425 EMBLEM SET-radiator grille "GX" 62330-H7225 EMBLEM SET-radiator grille "GL 5 SPEED" 15 62332-H3300 RETAINER-emblem GL,GX 16 08915-43410 WASHER-plain 4 GL,GX 17 08915-13410 WASHER-lock 4 GL,GX 18 08911-10410 NUT 4 GL,GX
Coupe
48 79200-H1020 MARK-"Nissan Full Automatic" with clip 49 63845-18000 CLIP-Tubular 50 79200-H2820 MARK-"Nissan Full Automatic" with clip (from '71-Apr.)
Truck
62311 ORNAMENT-FRONT 08915-43410 WASHER-PLAIN 2 -8910 08915-13410 WASHER-LOCK 2 -8910 08911-10410 NUT 2 -8910 62312-H1026 -7803 S 62312-G1025 7804-7907 S 62312-G1625 7908-8503 62312-G1660 8504-8910 62312-G1265 8910- カクガタ NISSAN 78801 EMBLEM-SIDE REAR,RH DX, ALL.7510-8910 76854-H1050 -8102 2 チューブラー トメ [tubular fasten] 76854-G1900 8103-8910 2 セッチャク トメ [adhesive fasten] 78801A CLIP-TUBULAR 63845-18000 6 DX, ALL.7510-8102
05 see above
06 see above
28 84822-H1000 EMBLEM-trunk lid(SUNNY 1200) -73
63845-18000 CLIP-tubular 3 DX -73
29 84823-H1000 MARK-deluxe DX -73
30 63845-18000 CLIP-tubular 2 DX -73
40 96905-15200 LABEL-leading capacity -8109
40 96905-89900 LABEL-LOADING CAPACITY 8110-8910
40 96905-89900 LABEL-LOADING CAPACITY 8910-
41 96907-G1100 LABEL-4 speed -73
42 96906-84600 LABEL-rear mane (LONG BODY)
42 96908-G1661 SB 8110- SUNNY
42 96908-G1665 SB 8110- SUNNY, LONG BODY
42 90890-G5100 8910- NISSAN
43 96906-A4600 LABEL-frigid zones (op.) カンレイチ シヨウ
LABEL
14806 LABEL-UNLEADED FUEL ONLY
14806-89901 8910- ムエン ニ カギル
14807 STICKER-FUEL
14807-89910
14808 LABEL-EMISSION CONTROL,A
14808-G2200 7510-7907
14808-H9460 7908-8109
14808-H9470 8110-8910
14808-95W00 8910-
21435 LABEL-CAUTION,RADIATOR
21450-89900 8110-8504
21435-89900 8504-8910 2
21435-89902 8910- キヤンペ ヨウ キイロ
84815U LABEL-REAR
96908-G1661 'SUNNY' short body 8110-
96908-G1665 'SUNNY LONG BODY' long body 8110-
96908-G5100 'NISSAN' 8910-
96901 PLATE-MODEL NUMBER
99070-89909 8504-8910
96905 LABEL-LOADING CAPACITY
96905-15200 -8109 <2,0> 96905-89900
96905-89900 8110-
96906 LABEL-FRIGID ZONE
96906-89900 *8110- カンレイチ シヨウ
99053 LABEL-OIL CAUTION
96903-89921 8110-8503
99053-G1900 8504-8910
99053-79965 8910-
99072 PLATE-CAUTION
48477-C0400 7510-8910 T/SIGNAL & DIM SW
96920-89900 8110-8306 <2,0> 96920-89910
96920-89910 8307-8910
48477-C0400 8910-
99072M TAG-KEY CAUTION
68215-89903 8110-8910
68215-89901 8910-
99090 PLACARD-TIRE LIMIT
99090-G1660 8110-8910
99090-95W00 8910-
99099 LABEL
21450-89915 8110-8503 LLC ヨウ30
21450-89935*8110-8504 LLC ヨウ50
21450-89916 8504-8910 LLC ヨウ30
21450-89936*8504-8910 LLC ヨウ50
21435-89915 8910- LLC ヨウ30
21435-89945*8910- LLC ヨウ50
01 62312-H1825 SET-ORNAMENT, RADIATOR GRILLE COUPE 02 08915-43410 WASHER-PLAIN 2 03 08915-13410 WASHER-LOCK 2 04 08911-10410 NUT 2 05 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID COUPE 84822-H1806 2 06 76854-H1600 EMBLEM-'DATSUN' BODY SIDE SEDAN,COUPE 2 08 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID COUPE 09 79855-N2200 MARK-NISSAN AUTOMATIC SEDAN,COUPE 10 79202-H1826 SET-ORNAMENT, REAR PANEL COUPE
01 62312-H1626 SET-ORNAMENT, RADIATOR GRILLE SEDAN 02 08915-43410 WASHER-PLAIN 2 03 08915-13410 WASHER-LOCK 2 04 08911-10410 NUT 2 06 76854-H1600 EMBLEM-'DATSUN' BODY SIDE SEDAN,COUPE 2 07 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN 09 79855-N2200 MARK-NISSAN AUTOMATIC SEDAN,COUPE 11 84823-H1000 MARK-DELUXE DELUXE 12 76852-H1000 BADGE-DELUXE SEDAN (DX)
