Propeller Shaft Part Numbers
Revision as of 23:44, 27 July 2015; view current revision
Categories: Propeller Shaft And Differential Carrier | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Driveshaft
Truck
Short Body
PROPELLER SHAFT (Short Body)
 1 37000-G1000 SHAFT ASS'Y-propeller (up to '72-2)
 2 37000-G1010 SHAFT ASS'Y-propeller (from '72-3)
   37000-G1011 SHAFT ASS'Y-propeller (from '73-9) 2 JOINT ATSUGI
   fixing propeller shaft
 2  01111-00081 BOLT (ℓ=25 mm) 4
    01111-00051 BOLT (ℓ=25 mm) 4
 3  08911-20810 NUT 4
 4  08915-13810 WASHER-lock 4
Long Body
1974
1974 PROPELLER SHAFT (Long Body)
 1 37000-G1400 SHAFT ASS'Y-propeller (up to '73-8)
   37000-G1410 SHAFT ASS'Y-propeller (from '73-9)
 2 01111-00051 BOLT 4
 3 08911-20810 NUT 4
 5 37510-G1401 BRACKET-center bearing, lower
 6 08154-02010 BOLT 2
 7 08915-14010 WASHER-lock 2
 8 37522-P0101 INSULATOR-center bearing
 9 37525-P0101 CUSHION-center bearing
10 74345-G1401 BRACKET ASS'Y-center bearing, upper
1997
FIG.H74-01 (74345)
37000 SHAFT ASSY-PROPELLER
 37000-G1410 LB 7510-9204 3 JOINT ATSUGI
 37000-95W00 LB 9204-     3 JOINT
37000A BOLT-FIX PROPELLER SHAFT
 01111-00051 4
 08915-13810 WASHER
 08911-20810 NUT
37000H NUT LB
 37163-G1400 7510-7712 <2,0> 73163-G1401
 37163-G1401 7801-
37000J WASHER-LOCK LB -7712
 38215-61001 -7712
37512 BRACKET-CENTER BEARING LB
 37510-G1401 7510-8503 <2,0> 37510-G1402
 37510-G1402 8504-
 08154-02010 BOLT
 08915-14010 WASHER
37521K BEARING KIT-CENTER LB
 37521-Y0125 7510-9204
 37521-W1025 9404-
 08911-20810 NUT
 08915-13810 WASHER
73525 CUSHION-CENTER BEARING LB
 37525-P0101
1 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL AUTOMATIC 0373- 2 37000-H5100
1 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1000
1 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1001
1 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT MANUAL 0972- 0 37000-H1010
1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1011
1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL MANUAL 0373- 2 37000-H1011
1 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC
1 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 0671- 2 37000-H1101
1 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT MANUAL
2 37111-20300 ASSY-YOKE SLEEVE AUTOMATIC
2 37111-18001 ASSY-YOKE SLEEVE MANUAL
3 37117-18000 YOKE-FLANGE
4 37125-18025 ASSY-JOURNAL WITH BEARING (2)
4 37125-H1025 KIT-JOURNAL WITH BEARING (2) 2 37125-18025
5 37130-18000 ASSY-RACE BEARING WITH OIL SEAL (8)
5 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL (8) AUTOMATIC 2 37130-18000
6 37147-18000 RING-SNAP BEARING RACE T=1.48 (8)
6 37148-18000 RING-SNAP BEARING RACE T=1.50 (8)
6 37149-18000 RING-SNAP BEARING RACE T=1.52 (8)
6 37146-18000 RING-SNAP BEARING RACE T=1.46 (8)
7 08120-82210 BOLT-HEX M8X1.25 (4)
7 01111-00061 BOLT-FIX PROPELLER SHAFT (4) AUTOMATIC 2 08120-82210
7 01111-00151 BOLT-FIX PROPELLER SHAFT (4) 3N71B 0371- 2 01111-00061
8 08911-20810 NUT-HEX M8X1.25 (4)
9 08915-13810 WASHER-LOCK M8 (4)
