Automatic Transmission Case Part Numbers
Revision as of 23:46, 27 July 2015; view current revision
Categories: Automatic Transmission | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
1 31020-X0100 ASSY-TRANSMISSION,AUTOMATIC 3N71B
2 31100-X0100 ASSY-CONVERTER,TORQUE 3N71B
3 31301-X0100 HOUSING-CONVERTER 3N71B
3 31300-X0100 HOUSING-CONVERTER 3N71B 0671-1272 22 31301-X0100
3 31300-X0104 HOUSING-CONVERTER 3N71B 0771-1272 22 31932-20304
3 31300-X0101 HOUSING-CONVERTER 3N71B 0173- 2 31300-X0100
4 31305-H0101 SCREEN-AIR INLET 3N71B
5 31307-H0100 GUARD-STONE (2) 3N71B
6 08310-51012 SCREW (6) 3N71B
7 31309-X0100 BOLT (6) 3N71B
8 31310-X0100 ASSY-CASE,TRANSMISSION 3N71B
8 31310-X0151 ASSY-CASE,TRANSMISSION 3N71B 0871- 2 31310-X0100
9 00931-10210 PLUG-SQUARE HEAD (3) 3N71B
10 31472-X0100 RACE-INNER,ONEWAY CLUTCH 3N71B
11 31484-X0100 WASHER-PLAIN (8) 3N71B
12 31488-F0600 BOLT (8) 3N71B
13 31625-X0100 PIN-ANCHOR END 3N71B
14 31381-X0100 BREATHER-AIR 3N71B
15 31921-X0150 ASSY-SHAFT,MANUAL 3N71B
15 31921-X0100 ASSY-SHAFT,MANUAL 3N71B 2 31921-X0150
16 31914-X0100 SEAL-O RING (14S) 3N71B
17 31922-X0100 WASHER-MANUAL SHAFT 3N71B
18 31924-X0101 ASSY-PLATE,MANUAL 3N71B
19 01211-00011 NUT 3N71B
20 31961-20300 LEVER-PARKING 3N71B
21 31970-X0100 ASSY-ROD,PARKING 3N71B
22 31963-X0100 RING-SNAP (6S) (2) 3N71B
23 31330-X0100 ASSY-EXTENSION,REAR 3N71B
24 31336-X0100 SEAL-OIL 3N71B
25 31335-X0100 GASKET-REAR EXTENSION 3N71B
26 08130-83010 BOLT (8) 3N71B
27 08915-43810 WASHER-PLAIN (8) 3N71B
28 31390-X0101 ASSY-PAN,OIL 3N71B
29 31397-X0100 GASKET-OIL PAN 3N71B
29 31397-X0101 GASKET-OIL PAN 3N71B 0373- 2 31397-X0100
30 31065-A4000 CLAMP-VACUUM TUBE 3N71B
31 08160-61210 BOLT 1 (14) 3N71B
32 08130-83010 BOLT (2) 3N71B
33 08120-85510 BOLT (4) 3N71B
34 08915-23810 WASHER-LOCK (6) 3N71B
35 30422-18000 COVER-DUST,CLUTCH HOUSING 3N71B
36 08360-61010 SCREW (3) 3N71B
37 08915-13610 WASHER-LOCK (3) 3N71B
38 31009-20300 BOLT-SELF LOCK,CONVERTER (4) 3N71B
39 31061-H1111 TUBE-VACUUM 3N71B
40 31064-20300 TUBE-ELBOW 3N71B
41 31067-E0100 TUBE-JOINT 3N71B
42 31063-H1110 CONNECTOR-VACUUM 3N71B
43 31080-H1110 ASSY-PIPE,OIL CHARGING 3N71B
44 08360-61214 SCREW-WITH WASHER 3N71B
45 31084-20300 SEAL-O RING (20S) 3N71B
46 31086-P2601 ASSY-GAUGE,OIL LEVEL 3N71B
47 31885-H1110 ASSY-TUBE,REAR LUBRICATION 3N71B
48 21638-P2600 JOINT-TUBE (2) 3N71B
49 21625-P2600 BOLT-CONNECTOR,OIL COOLER TUBE (2) 3N71B
50 21626-P2600 WASHER-SEAL (4) 3N71B
50 05412-1400P GASKET B (4) 3N71B 0772- 2 21626-P2600
51 32703-P2621 ASSY-PINION,SPEEDOMETER 3N71B
51 32703-P2622 ASSY-PINION,SPEEDOMETER (22T) OP,3N71B FOR RADIAL
52 32707-66300 ASSY-SLEEVE,SPEEDOMETER 3N71B
53 32709-14600 SEAL-OIL 3N71B
54 32710-14600 RING-O 3N71B
55 32873-14600 PIN-RETAINING 3N71B
56 32718-14600 PLATE-LOCK 3N71B
57 08360-61214 SCREW-WITH WASHER 3N71B
58 31397-X0125 KIT-GASKET & SEAL AUTO TRANS 3N71B
