Air Cleaner
Revision as of 11:17, 6 August 2015; view current revision
Category: Engine Mechanical
Datsun 1200s use a typical paper-type engine air filter in a real metal air cleaner.
1977 VB210 Japan is similar:
Tightening
Turn the wingnut down until it contacts the air cleaner lid. Then tighten the wing nut 3 turns:
Removal
The air cleaner must be removed to inspect the carburetor or vacuum hoses.
Cleaner Removal
  1. If you have a warm/cold air cleaner, remove the hoses as outlined below
  2. Twist and pull the thick breather hose straight up out of the rocker cover
  3. Remove the two 10mm-headed bolts from the side of the air cleaner away from the engine
  4. Remove the one 10mm-headed bolt from the bracket next to the rocker cover
  5. Untwist the wingnut holding the air cleaner top on. Carefully remove the washer & rubber piece
  6. lift the lid off and remove the air filter element
  7. lift the air cleaner body straight up
Hot/Cold Air Cleaner
If you have an warm/cold air type air cleaner do this first before attempting to remove the air cleaner:
  1. Carefully twist the hot air tube to loosen it. If it won't twist, unscrew the clamp first. Be careful not to damage the cardboard tubing. After it is loose, pull it down off the bottom of the air cleaner snout. Leave the bottom connection tight, only separate it from the air cleaner
    full
  2. ATC type (vacuum controlled) do this: Twist and pull the ATC vacuum hose out of the intake manifold port
    full
Also See
Also see:
* GX Air Cleaner
* Air Intake Systems for upgrades/alternatives, including cold air intakes
Anti-Icing
To prevent ice up in winter (carb icing can over many degrees above freezing), air cleaners for temperate markets have a temperature control. For example, this Japan-market air cleaner:
Automatic Temperature Control
USA models use an Automatic Temperature Control air cleaner for year-round constant inlet temperature. For details, see ATC.
220.JPG 291.jpg 759.gif 1005.jpg 1133.jpg 1693.jpg 2687.jpg 2771.jpg 2772.jpg 2773.jpg 3149.jpg 3461.jpg 3492.jpg 3503.jpg 3712.jpg 4151.jpg 5252.jpg 5315.jpg 5468.jpg 5773.jpg 7495.jpg 8115.jpg 8996.jpg 9006.jpg 9112.jpg 9113.jpg 11690.jpg 12636.jpg 12938.jpg 13219.jpg 13380.jpg 13817.jpg 14541.jpg 21032.jpg 14541.jpg 14545.jpg 14757.jpg 14758.jpg 14856.jpg 14992.jpg 14993.jpg 15631.jpg 15675.jpg 15694.jpg 15695.jpg 15729.jpg 16116.jpg 16117.jpg 16663.jpg 16774.jpg 16775.jpg 16776.jpg 16866.jpg 16893.jpg 17031.jpg 17032.jpg 18165.jpg 18250.jpg 18929.jpg 18976.jpg 19110.jpg 19233.jpg 19454.jpg 20723.jpg 20805.jpg 20806.jpg 21214.jpg 21533.jpg
