Zenith fuel injection ZEEMS * KIT, GSKT, MANFLD * HARNESS, ENG, A-15, EFI, ZEEMS * ASSY, THROTTLE BDY, W/O ECU * SENSOR, COOLANT, A15, EFI * SENSOR, AIR TEMP, A15, EFI * SENSOR, MAP, A15, EFI * ECU, NISSAN, A15, EFI * FILTER, FUEL, EFI * PUMP, FUEL, EFI * SENSOR, OXY, A15, EFI * O-RING KIT, FUEL PRESS & INJ * REGULATOR, FUEL PRESSURE * INJECTOR, GASOLINE (O-RING INCL.)
A15 Industrial Engine
Zenith Power Products http://zenithpp.com/engines_a15.htm Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm Continuous output (SAE Gross J1349) 39 HP/3,600 rpm Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm Fuel and type Gasoline, 4-cycle, O.H.V. Cylinder arrangement 4 in-line Combustion chamber Wedge shape Bore x stroke 76mm x 82mm (2.99 x 3.23 in) Total piston displacement 1,487 cc (90.74 cu in) Compression ratio 9.0 : 1 Length x width x height (standard model) 527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in) Dry weight (standard model)* 103kg (227 lb)
