Fill the windshield washer bag with wiper fluid. In summer, plain water may be used, but in winter only wiper fluid with anti-freeze properties should be used to prevent freezing damage to the pump.
Daily Care
1972 USA Owners manual (see page 25 for Daily Care information): |
- Remove cap and top up the Kangaroo Bag.
- Turn key to ON, twist wiper switch to verify correct washer action.
Testing
To test the washer motor:
- Put some water in the bag
- Connect Blue/Red wire to 12V +
- Connect Black/blue wire to ground/earth
The washer pump should make noise and squirt water
If the pumps makes noise, but no water squirts, the nozzie atop the back of the bonnet may be clogged. Take a sewing pin and insert in the two little holes.
Nozzle
Nozzle Repair
If the nozzle break off where the hose attaches, use a rubber fitting to repair it. I used a 70s-80s GM vacuum fitting that has a small hole in one side and a large hole in the other side. Jam the small hole onto the Nozzle and fit the hose into the larger hole.
Or buy a new nozzle at about $15 USD.
27480-H1001 ASSY-BAG WINDSHIELD WASHER $138.33 USD * replaces 27480-89901 ASSY-BAG WINDSHIELD WASHER
27440-H1001 NOZZLE ASSY-WASHER B110 * 28930-G1900 NOZZLE ASSY-WASHER B120
COMPARISON 27480-89900 521 0568- [same as B110] 27415-89900 520 -0468 [uses external pump] 510 [uses plasic tank] PL620 [uses plasic tank]
28930-G1900 buy at Bprojects
Kangaroo Bag Clone
Bag with internal 12V pump. As low as $30 USD.
- 33199
- DGEWP16
- GT SP-401104
- YH-XDU
- Ferrari 308: part number 3567W
- Honda Civic IAT (Bag Type)
- FIAT (Bag Type)
- Zhenqi ZQ-XDu
Denso
NipponDenso (ND) washer bag, Denso Corporation. DENSO is a member of the Toyoda Group of companies.
- 060800-1330 WASHER ASSY
- 160200-1570 WASHER ASSY
Mitsuba
ミツバ Mitsuba has a strong historical relationship with Honda.
Mitsuba EW-4B (also see MITSUBA EWP16, EW-3B, 38510-810)
CAUTION
Always use clear washer solvent with pure water
Do not use soap water
