- Also see: Performance
Body Dimensions
- Height: 1390 mm
- Tire radius: 286 mm
- Width: 1495 mm
- Length: 3830 mm
- Front Bumper to axle: 605 mm
- Wheelbase: 2300 mm
- Rear axle to rear body edge: 915 mm
- Rear bumper overhang: 10 mm
- Ground clearance: 17.0 mm
- Top of bumper: 580 mm from ground
- Center of rear lights: 720 mm from ground
- Track width: 1240 mm (tire tread centers)
- Headlight Centers: 1125 mm
Ground clearance is measured from the bottom of the differential housing. So when you think about it, the tire size will make a difference...
- Nominal Tire diameter: 21.7 inch (155SR-12, factory size)
