The room lamp, also known a dome light.
Put the switch in the middle position so it operates from the door switches (if so equipped).
1972 USA Owners manual (Page 06 ... ):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
alternative interior headliner light
Car
These parts are the same for both B110 and B210.
Pickup
buy from Bprojects 26410-04100 LAMP ASS'Y-room -7803 IKI [single wire] 26410-04400 LAMP ASSY-ROOM 7803- IKI [two wire] 26410-G1000 LAMP ASSY-ROOM -7803 IMASEN
Two Wire type: * Red/yellow: bulb 12V * Black: earth/ground
B10
B10 sedan and VB10 wagon uses the same lap as 1200 ute. IKI brand (市川, Ichikawa).
26410-04100 ASS'Y-LAMP, room STD IKI 26410-04400 ASS'Y-LAMP, room DELUXE IKI
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room 26410-04400 ASS'Y-LAMP, room * 26411-04100 LENS * 26715-89900 BULB (12V 6W) * 5-10813-1 SCREW-machine (2)
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
26410-23100 ASSY-LAMP ROOM -0968 EXC CAN <x> 26410-23101 * 1968 CANADA used dual rectangular side lamps 26410-A0800 ASSY-LAMP ROOM 0968-
Door Switch
- The 1200 door switch is a single wire unit that grounds the wire when the door is opened
- The 1973 USA door switch is a double-switch (with an extra wire)
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box. The switch has three positions:
* Off * Auto (center) * On
In the auto position, the light is grounded by the Door Switch (BR wire in A-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner.
Dash harness has the door switch/room lamp wiring
Black Ground5036 Black/red Ground from door switch Red/blue Always Hot
- Ground wire out of Lamp may be a short wire that bolts to the roof metal
- Some Lamps have no Ground wire (black wire) but ground through the lamp screws
1973 used a relay, but with the same wire colors. The 1973 door switch is a double-switch (with an extra wire).
